      0WR7-0JH
      <User Management>
      You can configure the settings for managing users of the macine with a user authentication application.
      Item
      Description
      Configure settings to establish a user authentication management system that is best suited for the environment of your organization, enabling you to manage access of users to the machine.
      <System Manager Information Settings>
      Set the System Manager information for the machine. Changing the System Manager ID and PIN
      Setting Value
      <System Manager ID>: Enter a number of up to seven digits. (7654321)
      <System Manager PIN>: Enter a number of up to seven digits. (7654321)
      <System Manager>: Enter the name of an administrator.
      <E-Mail Address>: Enter the E-mail address of the administrator.
      <Contact Information>: Enter the contact information of the administrator.
      <Comment>: Enter comments.
      DeviceAdmin : No
      NetworkAdmin : No
      Can be set in the Remote UI: Yes
      Device Information Distribution Available: Yes
      <Department ID Management>
      Select whether to manage users in groups by assigning users to Department IDs. Configuring the Department ID Management Settings
      Setting Value
      <On> (→), <Off>
      <On>:
      <Register PIN> or <Register Department ID> (→. The name of the setting value may vary depending on the setting of the machine.)
      <Page Totals> (→)
      <Allow Printer Jobs with Unknown IDs>: <On>, <Off>
      <Allow Remote Scan Jobs with Unknown IDs>: <On>, <Off>
      <Register PIN> or <Register Department ID>: <Register> (→), <Edit> (→), <Delete>, <Limit Functions>* (→)
      <Page Totals>: <Clear>, <Print List> (→), <Clear All Totals>, <Large 2 Count Management>
      <Register>/<Edit>: <Department ID>, <PIN>*, <Turn Limit On/Off and Set Page Limit> (→)
      <Limit Functions>*
      <Store/Access Files>, <Fax/I-Fax Inbox>: <On>, <Off>
      <Send/Fax>: <On>, <Off>
      <Other>: <On>, <Off>
      <Print List>: <All>, <Black & White Only>, <Color Only>
      <Total Print Limit>: <On>, <Off>, Set Page Limit (0-999999)
      <Copy Limit>: <On>, <Off>, Set Page Limit (0-999999)
      <Color Scan Limit>: <On>, <Off>, Set Page Limit (0-999999)
      <Black & White Scan Limit>: <On>, <Off>, Set Page Limit (0-999999)
      <Print Limit>: <On>, <Off>, Set Page Limit (0-999999)
      * Displayed when DeparmentID Authentication is used.
      DeviceAdmin: No
      NetworkAdmin: No
