      0WR7-03F
      Selecting Document Type for Copying
      You can select the optical image quality for the copy depending on the document type such as documents with only characters or magazines with photographs.
      1
      Place the document. Placing Documents
      2
      Press <Copy> on the Main Menu. <Main Menu> Screen
      3
      Press <Options> on the Copy Basic Features screen. Copy Basic Features Screen
      4
      Press <Original Type>.
      5
      Select document type.
      If you select <Printed Image>, you can copy printed photographs (photographs made with halftone dots) with optimal print quality.
      If you select <Photo Printout>, you can copy photographs printed on photographic paper with optimal print quality.
      NOTE:
      <Printed Image> <Photo Printout> are displayed when <Photo Printout Mode> is set to <On>.
      <Copy>  <Photo Printout Mode>
      <Photo> is displayed when <Photo Printout Mode> is set to <Off>.
      6
      Press <OK>  <Close>.
      7
      Press .
      Copying starts.
