Item
Description
<Register/Edit Favorite Settings>
You can register favorite copy settings. Configure the copy settings beforehand.
IMPORTANT:
Confirm the contents to be deleted.
Setting Value
<M1> to <M9>: <Register> (→
), <Rename> (→ ), <Delete> (→ ), <Check Content> (→ ) <Register>: Register the current setting. <Rename>: You can change the name of the setting. <Delete>: You can delete the setting. <Check Content>: You can check the content of the setting.DeviceAdmin: Yes
NetworkAdmin: Yes Can be set in the Remote UI: No Device Information Distribution Available: No |
<Change Default Settings>
You can change/initialize the default settings for <Copy>. Configure the copy settings beforehand.
Setting Value
<Register> (→
), <Initialize> (→ ) <Register>: Register the current setting. <Initialize>: You can initialize the default setting.NOTE:
Even if a cascade copy printer is stored in Default Settings, if the main power of this machine or the cascade copy printer is turned OFF and ON again, the stored settings change to Local Printer. To use the stored cascade copy printer as the Default Setting, it is necessary to register the Default Settings again.
DeviceAdmin: Yes
<Register Options Shortcuts>
You can register modes in the shortcut keys displayed on the Copy screen. You can register desired buttons from <Options> and <Favorite Settings>. This feature is useful when you want to register frequently used functions. Registering Frequently Used Copy Settings
Setting Value
Shortcut keys: Press a shortcut key to register a function. (→
) <Register Options Shortcuts: Select Feature>: Select a function to register.<Unassigned>: Assigns no function to the shortcut key you selected.
<Preset Favorite Settings>: You can register a favorite setting. DeviceAdmin: Yes
<Auto Collate>
If you set Auto Collate to <On>, the machine automatically sets the Collate (Offset) when originals are placed in the feeder. This is useful when making multiple sets of copies, because you do not need to remember to select the Finishing mode.
Setting Value
<On>:
<Offset at Same Time>: <On>, <Off> <Off> NOTE:
If Auto Collate is set to <On> and a finisher is attached, the Collate and Offset Collate modes are set. However, if no finisher is attached, only the Collate mode is set.
DeviceAdmin: Yes
NetworkAdmin: Yes Can be set in the Remote UI: No Device Information Distribution Available: Yes |
<Image Orientation Priority>
If Image Orientation Priority is set to <On>, the machine always copies an image in the same orientation as the original image. This is because the images on originals may be copied upside down, depending on the copy mode set.
Setting Value
<On>, <Off>
DeviceAdmin: Yes
<Auto Recognize Original Orientation>
Setting this mode enables the machine to use information such as the size of the original and the copy ratio to determine the most suitable orientation for the specified paper size. The machine then automatically rotates the image if necessary.
Setting Value
<On>, <Off>
NOTE:
If you are enlarging LTR or STMT originals are enlarged onto 11" x 17" or LGL copy paper, Auto Orientation is not performed even if you select <On>.
Only the images of standard size originals up to LTR size can be rotated when the copy ratio is set to 100%.
If you set Automatic Paper Selection and the most suitable paper size is not available, the paper source that is loaded with paper of the same size is displayed as optimal, even if the orientation is different.
DeviceAdmin: Yes
<Photo Printout Mode>
You can enable the Printed Image mode. If this mode is set to <On>, you can select <Printed Image> or <Photo Printout> for the image quality when copying.
Setting Value
<On>, <Off>
DeviceAdmin: Yes
<Register Remote Device for Cascade Copy>
You can register a printer for cascade copying, and check the information for and delete registered printers. Copying with Two Canon Multifunction Printers (Cascade Copy)
IMPORTANT:
If <Use IPv4> in <IPv4 Settings> in <Preferences> is set to <Off>, you cannot register a cascade copy printer.
Setting Value
<Register>: Enter the IP address or host name of the printer to register.
<Details>: Displays the details of the selected printer. <Delete>: Deletes the selected printer. NOTE:
Set the same Department ID and PIN as the machine for the cascade copy printer. (See Setting the Department ID Management)
You cannot delete a cascade copy printer while cascade copying with the printer.
DeviceAdmin: Yes
NetworkAdmin: Yes Can be set in the Remote UI: Yes Device Information Distribution Available: No |
<Cascade Copy Communication Timeout>
You can set to cancel cascade copying when there is no response from the cascade copy printer for a certain period of time. You can set the time from 5 seconds to 30 seconds, in 1 second increments.
Setting Value
5 to 30 sec.
NOTE:
Jobs that timeout (jobs that are not received by the cascade copy printer) are deleted.
DeviceAdmin: Yes
<Speed Priority for Copying from Feeder>
You can give a priority to speed over accuracy when copying from feeder.
Setting Value
<On>, <Off>
NOTE:
This function is effective only in the following situations.
The number of copy is set to 1.
The equal copy ratio is set.
The document and output paper sizes are LTR/LTRR/STMT/STMTR.
Copy settings are not configured except the document size and paper type.
DeviceAdmin: Yes
<Job Separator Between Groups>
When copying two copies or more with <Group (Same Pages)>, you can insert sheets between each page group. If you select <On>, select a paper source.
Setting Value
<On>: <Change> (→
)<Off> Select the paper to use.DeviceAdmin: Yes
