      0WR7-097
      Printing Files in Memory Media
      Even if the machine is not connected to a computer, or a printer driver is not installed in the computer, you can print files saved in memory media from the machine.
      1
      Press <Access Stored Files> on the Main Menu. <Main Menu> Screen
      2
      Press <Memory Media>.
      3
      Select the desired memory media.
      For information on the items on the screen and instructions on how to use them, see Working with Files and Folders in Memory Media.
      4
      Select a file and press <Print>.
      If you select PDF or XPS files, proceed to step 6.
      5
      Select the paper source and press <OK>.
      6
      Enter the number of prints using the numeric keys.
      If you select multiple files in step 4, press <Change No. of Copies> and enter the number of prints.
      7
      Specify the print settings as necessary.
      NOTE:
      To print a file with a password, press <Options>  <Password to Open Document>  <Encryption Password> or <Policy Password>, enter the password, and press <OK>. To print PDF files that forbid printing, or print PDF files that only allow low-resolution printing in high resolution, enter the specified password.
      8
      Press <Start Printing>.
      Printing starts.
      To cancel printing, press <Cancel>  <Yes>.
