      0WR7-095
      Saving Documents in Memory Media
      Follow the procedures below to convert scanned documents into a file format commonly supported by a computer to save in memory media. You can conveniently use this method when you need to move files to a computer not connected to a network.
      1
      Set the document. Placing Documents
      2
      Press <Scan and Store> on the Main Menu. <Main Menu> Screen
      3
      Press <Memory Media>.
      4
      Select the desired memory media.
      For information on the items on the screen and instructions on how to use them, see Working with Files and Folders in Memory Media.
      5
      Display the save location and press <Scan>.
      6
      Specify the scan settings as necessary.
      7
      Press .
      Documents are scanned and saved as files.
      To cancel scanning, press <Cancel> or   <Yes>.
      When <Press the [Start] key to scan the next original.> is displayed
      NOTE:
      To check the result of saving, press   <Store>  <Job Log>. If <NG> is displayed, the file is not saved successfully. Try the operation again.
