To cancel receiving, press
<Receive> <Job Status> select a document <Cancel>.If a received I-fax is divided, the data finished being received is printed when 24 hours pass after the start of the reception, and the subsequent data is deleted. You can change the time as necessary. <Set Fax/I-Fax Inbox>
<Divided Data RX Timeout> |
<Select Drawer>|
To receive I-faxes manually
Press
<Receive> <Job Log> <Check I-Fax RX>. On the Main Menu (<Main Menu> Screen), pressing <Fax/I-Fax Inbox> <Memory RX Inbox> <Divided Data RX Inbox> enables you to check the receiving statuses of I-faxes divided and their data size. |
TIPS
You can save paper when printing.
<Common Settings>
<Print on Both Sides><Common Settings>
<2 on 1 Log><Common Settings>
<Reduce Fax RX Size>You can include information, such as reception time, in received documents when printing. <Common Settings>
<Print RX Page Footer> |
