      0WR7-057
      Recalling Previously Used Copy Settings (Previous Settings)
      You can recall the previously used copy settings. The details of the recalled setting can be changed before copying.
      1
      Place the document. Placing Documents
      2
      Press <Copy> on the Main Menu. <Main Menu> Screen
      3
      Press <Previous Settings> on the Copy Basic Features screen. Copy Basic Features Screen
      4
      Select the setting to recall and press <OK>.
      When personal authentication management is in use, the machine recalls the settings specified in the past by the user who are logging in to the machine.
      5
      Press .
      Copying starts.
      If you restarted the machine, the Cascade Copy setting (Copying with Two Canon Multifunction Printers (Cascade Copy)) is recalled as the previous setting only for the machine you are using.
