      0WR7-04U
      Combining Jobs with Different Settings Into a Single Job (Merge Job Blocks)
      You can scan multiple documents with different settings, and then combine the jobs into a single job and print it out. For example, scan one document with the Hole Punch setting and another document with the 2-sided setting, after that, you can combine these documents into a single job and add page numbers or attach covers to the whole output.
      1
      Press <Copy>.
      2
      Press <Options> on the Copy Basic Features screen. Copy Basic Features Screen
      3
      Press <Merge Job Blocks>.
      4
      Specify settings that are applied to all of the documents and press <OK>.
      To configure <Finishing>, see Basic Copy Operations.
      To configure <Job Separator>, see <Paper Output Settings>  <Job Separator Between Jobs> or <Job Separator Between Copies>.
      To configure <Secure Watermark>, <Document Scan Lock>, see Restricting Copying of Confidential Documents.
      To configure <Page Numbering>, <Copy Set Numbering>, <Watermark>, <Print Date>, see Functions Useful for Making and Managing Material.
      To configure <Job Done Notice>, <Store in Mail Box>, see Useful Copy Functions.
      5
      Place the first document, configure settings on the Copy Basic Features screen, and press .
      Scanning starts. When scanning is complete, the screen appears prompting you to scan the next document.
      If you want to keep the setting specified in this step for the next document, proceed to step 7.
      If you want to change some of the settings such as copy ratio or density for the next document, press <Change Settings> on the screen, change the settings, and proceed to step 7.
      6
      Press <Scan Settings of Next Block>.
      7
      Place the next document, configure settings on the Copy Basic Features screen and press .
      Repeat steps 6 and 7 for the documents you want to combine.
      To apply the last setting you used to the document, place the document and press .
      8
      Press<Check/Merge All Blocks>.
      9
      Enter the number of copies and confirm the settings for the scanned documents.
      <No. of Prints>
      Enter the number of copies using the numeric keys.
      <Check Overall Settings>
      You can check the settings specified in step 4.
      List of scanned documents
      Displays the information of the scanned documents as a list.
      The number in appears as 1, 2, 3... in the order that the documents are scanned, and the copies are printed order. If you want to change the order, press <Clear Selection> in  and specify the order.
      <Add Cover>/<Insert Sheets>
      You can include covers and insert sheets (chapter pages).
      <Edit & Adjust>
      You can preview pages, or delete specific pages or jobs.
      <Add Originals>
      You can scan more documents to add to the output.
      <Add from Mail Box>
      You can call documents from the Mail Box to add to the output. Making Simple Edits to Files
      <Details>
      When selecting documents in , <Details> is displayed. You can confirm the settings for each document.
      <Print Sample>
      You can print a copy sample to check the result before making a large amount of copies. Checking the Copy Results
      <Clear Selection>/<Select All>
      You can change the document order in .
      10
      Press <Start Printing>.
      Copying starts.
