      0WR7-04J
      Shifting the Original Image
      This function enables you to make copies with the entire original image shifted to a corner or the center. Shift the image when you want to make blank space on the page to input or arrange text and images on material.
      Shifting the Image to a Corner or the Center
      You can make margins around the image by copying to paper larger than the document or by reducing the copied image to a size smaller than the paper size. Within these margins, the image can be shifted to a corner or the center of the paper.
      1
      Place the document. Placing Documents
      2
      Press <Copy> on the Main Menu. <Main Menu> Screen
      3
      Press <Options> on the Copy Basic Features screen. Copy Basic Features Screen
      4
      Press <Shift>.
      5
      Press <By Position> and select which direction to move the image.
      Press an arrow button or <Center> to select the direction of movement.
      6
      Press <OK>  <Close>.
      7
      Press .
      Copying starts.
      Specifying Moving Distance
      If no blank space exists because the document and the paper are the same size, or if you want to shift images by a few millimeters, specify the moving distance.
      1
      2
      3
      4
      Press <Shift>.
      5
      Press <By Numeric Keys> and specify the moving distance.
      Press <Set> in <Front Side> and specify the moving distance. Press the up/down/left/right buttons indicating directions and enter the moving distance using the numeric keys.
      If you want to move the image on the back side when copying both sides, the <Back Side> setting is needed. To move to the same position as the front side, press <Same as Front Side>. To move symmetrically, press <Opposite to Front Side>. To move to a position different from the front side, press <Set> and enter the moving distance.
      6
      Press <OK>  <Close>.
      7
      Press .
      Copying starts.
