When scanning originals that are smaller than the scanning size, frame lines of the originals may appear in the scanned image. When scanning a thick book, dark borders may appear. This function enables you to erase these frame lines and dark borders. You can also set the machine to not copy punch holes in the originals.
Place the original with punch holes on the platen glass. Placing in the feeder may result in damage.
<Erase Frame>.
Erasing the frames in copies of documents|
1
Press <Erase Original Frame> and check <Original Size>.
![]() If the size displayed in <Original Size> is different from the size of the original, press <Change> to select the size.
2
Enter the width of the frame to erase.
Erasing dark borders in copies of books|
1
Press <Erase Book Frame> and check <Original Size>.
![]() If the size displayed in <Original Size> is different from the size of the book, press <Change> to select the size.
2
Press <Center> or <Sides> and enter each erasing width.
Erasing punch holes in copies of documents|
1
Press <Erase Binding> and select the punch hole location.
2
Enter the erasing width.
<Close>.
