Other Finishing Functions
Depending on the installed options, you can use other finishing functions. Optional Equipment
Rotate 90 Degrees
You can output each set of paper in alternating portrait and landscape orientation.
Hole Punch
You can make punch holes for filing.
Saddle Fold
Using the booklet finisher, you can fold the output sheets in half. You can specify how many sheets to fold together and which page to start printing on.
Depending on the paper type, you cannot use finishing functions. Specifications
13WJ-04C
