If both the host and client machines are imageRUNNER ADVANCE series models, the device information can be distributed. It is also possible to receive some setting information from models other than those in this series. However, some information may not be distributed properly. <Device Management>
![]() Some device information may not be distributed properly when certain optional equipment is attached to the machine.
Check the basic configuration.
Are the host and client machines connected properly over the network?
Are the TLS key and certificate configured on the client machine?
![]() When automatically searching for the client machines, make sure that the SLP communication is available between the machines. Monitoring the Machine From Device Management Systems
Register the distribution destination of the device information.
On the host machine, register the client machines that will receive the distributed device information. Registering the Device Information Destinations
To perform user authentication when device information is received, configure the necessary settings on the host and client machines. Performing User Authentication when Distributing Device Information
Distribute the device information.
On the host and client machines, check the results of device information distribution.
