![](./images/global_images/1T0003419081/b_style_note1_L=en-GB.gif)
Confirm before handlingIf the optional paper deck is installed, pull it away from the machine.
Open the paper drawer.
If paper is jammed, gently pull it out in the direction of the arrow.
Push the paper drawer in until it clicks.
When closing the paper drawer, be careful not to get your fingers caught, as this may result in personal injury.
Open the upper-right cover of the paper drawer.
Open the upper-right cover and lower-right cover of the paper drawer.
When the Cassette Feeding Unit is attached
When the High Capacity Cassette Feeding Unit is attached
The paper deck may not be able to be opened if the machine is in the Sleep mode. Cancel the Sleep mode before opening the paper deck.
Check carefully, as the paper may be jammed in a location that is difficult to see.
