Replacing the Staples of the Booklet Finisher
Take care not to be injured by staples.
Replacing the Staples of the Staple Unit
1
Open the front cover of the finisher.
2
Pull out the staple case.
Hold the green handle on the staple case and pull it straight out.
3
Remove the empty staple cartridge from the staple case.
4
Remove the new staple cartridge from its box.
5
Load the new staple cartridge to the staple case.
6
Hold the green handle on the staple case and push it in as far as it will go.
7
Close the front cover of the finisher.
Replacing the Staples of the Saddle Stitcher Unit
Confirm before handling
If there is any paper in the booklet tray, remove it.
1
2
Pull out the saddle stitcher unit.
3
Remove the (two) staple cases while pulling down the lever towards yourself.
4
Remove the empty staple cartridge.
While holding both sides of the top of the empty staple cartridge, lift up the staple cartridge to remove it.
5
6
7
Install the (two) staple cases to the saddle stitcher unit.
Push them in as far as they will go.
8
Push in the saddle stitcher unit, and close the front cover of the finisher.
9
Press
<Adjustment/Maintenance>
<Adjust Action>
<Saddle Stitch Staple Repositioning>
<Start>.
Since paper is required to perform staple repositioning, load A3, B4, or A4R size paper in a paper source in advance.
