A lock is not included with the "Removable HDD Kit." Purchase a lock that is commercially available for security.
If you use the option together with the "HDD Mirroring Kit," you can store data onto two hard disks. System Options
If the <E602-0001> message appears on the touch panel display when the machine starts, a hard disk may not be set in the hard disk holder. Turn OFF the machine and check that the main power indicator on the control panel is not lit, and then check whether the hard disk is set. If the error message still appears even though a hard disk is set, contact your local authorized Canon dealer.
1
Open the right cover of the machine.
2
Open the front cover of the Removable HDD Kit.
If the front cover is locked, unlock the front cover beforehand.
3
Hold the handle on the hard disk holder and being careful of the orientation, insert the holder.
4
Close the front cover.
![]() Lock the front cover if necessary.
5
Close the right cover of the machine.
1
2
3
Hold the handle on the hard disk holder and remove the holder.
![]() ![]() Store the hard disk holder with the circuit board of the HDD on the bottom.
Do not store the hard disk holder in the upright position, as doing so may damage the holder.
4
5
