While you are operating on the SMS screen, do not use the [Back] button on your Web browser, the SMS screen may not operate properly.
[Device Serial Number: <Serial Number>]
Menu
[Enhanced System Application Management]
Installs, uninstalls, and manages system applications that can be enhanced. You can change the login service from this page. Changing Login Services
[System Application Management]
Starts and stops the usage of installed system applications. Changing the SMS login method is performed from this page.
[System Information]
Displays the version and the operation status of a system application.
[MEAP Application Information]
Displays a list of applications (excluding system applications) currently installed and already uninstalled.
[Check License]
Displays the detailed information of license files before installation.
[Change Password]
Normally, it is not necessary to change this setting. Configure this setting especially when you use the "DepartmentID Authentication" login service.
[MEAP Application Setting Information Management]
Displays or deletes information related to MEAP application settings.
[MEAP Application Log Management]
Downloads or deletes log data such as the usage history of MEAP applications.
[Resource Information]
[MEAP Application Management]
[Installed]
The MEAP application has been installed, but it is not ready for use. Even if you restart the machine after stopping the use of the MEAP application, [Installed] is displayed.
[Started]
The MEAP application is ready for use.
[Stopped]
The MEAP application is not ready for use.
[Starting]
The MEAP application is starting.
[Starting]
The MEAP application is stopping.
[Installed]
The valid license is installed.
[Not Installed]
Unable to use the MEAP application as the license file is not installed or is disabled.
[Over Limit]
Some counters set for the MEAP application exceed the maximum value.
[Invalid]
The validity for the license file has expired or all counters set for the MEAP application exceed the maximum value.
[Unnecessary]
You can use the MEAP application even if you do not have a license file.
[To Portal]/[Log Out]
Starting or stopping the use of a MEAP application
1
Click [MEAP Application Management].
2
Click [Start] / [Stop] for the MEAP application to be used.
![]() ![]() Depending on the MEAP application, you need to restart the machine. Follow the on-screen instructions and restart the machine.
Configuring the MEAP application's authentication information
1
click an application to set the authentication information. |
2
Click [Authentication Information Settings].
3
Enter the user name and password and select the login destination.
4
Click [Update].
The [Authentication information has been set. Department ID: <ID>] message is displayed.
![]() To cancel authentication information
Click [Delete]
[Yes] on the authentication information page in step 3. |
Uninstalling a MEAP application
1
[Uninstall] for the application to be uninstalled.![]() |
2
Click [Yes].
If you uninstall a MEAP application, you may be required to restart the machine. Follow the on-screen instructions to restart the machine.
![]() If the "Export Package of this application will be unavailable." message is displayed, the MEAP application you are uninstalling is linked with other applications. If this MEAP application is uninstalled, other applications may not be able to be used.
