If you want to restore device information to what it was before it was updated, only the data of the very last update is available to be restored.
While receiving and updating device information, the screen indicating that the settings are being updated appears. Operations on this machine cannot be performed until the update completes.
(Settings/Registration).
You cannot restore the settings of Workflow Composer to what they were before the device information was updated.
If you do not restore data for [Settings/Reg. Value] and [Address Book] at the same time, the settings in [URL Send Settings] for [Set Fax/I-Fax Inbox] and [Mail Box Settings] may be erased.
(Settings/Registration). |
Before setting <Settings/Reg. Value>, <Dept. ID>, or <Address Book> to 'Off', it is necessary to set a default key in [Preferences] (Settings/Registration). (See "Setting the Key Pair Used With SSL Encrypted Communications.")
If the received information of a paper type includes a value outside the setting range, the paper type may not be registered.
(Settings/Registration).|
[All]:
Registers all received paper information.
[Basic Only]:
Registers only the basic information of each paper type.
