Checking a Device Signature/User Signature Certificate
You cannot press [Confirm Device Signature Certificate] if the certificate and key pair for adding a device signature have not been generated. For more information on the certificate and key pair for adding a device signature, see "Setting/Confirming a Key Pair and Device Certificate."
You cannot press [Confirm User Signature Certificate] if the certificate and key pair for adding a user signature have not been installed. For more information on installing a user certificate, see "Installing a Certificate File."
Confirming the Device Signature Certificate
This section explains how a general user can check the certificate required for sending a PDF or XPS file with a device signature.
You can only check the device certificate with the following procedure. For more information on how the administrator can confirm the key pair and device certificate information, see
The following procedure can be performed when the Device Signature PDF/XPS function is available for use. For information on the optional products required to use the Device Signature PDF/XPS function, see "
Optional Products Required for Each Function (imageRUNNER ADVANCE C9280 PRO/C9270 PRO)" or "
Optional Products Required for Each Function (imageRUNNER ADVANCE C7270/C7260)."
Press
(Settings/Registration).
Press [Management Settings] → [Device Management] → [Confirm Device Signature Certificate].
To verify a certificate, press [Verify Cert.].
Press [OK].
Checking a User Signature Certificate
This section explains how a general user can check the certificate required for sending a PDF or XPS file with a user signature.
You can only check the user certificate for the logged in general user with the following procedure. For information on how the administrator can check the key pair and user certificate for all of the general users, see
"Confirming a Key Pair and User Certificate."
The following procedure can be performed when the User Signature PDF/XPS function is available for use. For information on the optional products required to use the User Signature PDF/XPS function, see "
Press
Press [Management Settings] → [Device Management] → [Confirm User Signature Certificate].
Press [OK].
