Verifying Certificate Validity Using Certificate Revocation List
You can verify the validity of the certificate by using a Certificate Revocation List (CRL). You can also delete an unnecessary Certificate Revocation List.
Press [Management Settings] → [Device Management] → [Certificate Settings].
Press [Cert. Revocation List (CRL)] → select the next step.
Verify the validity of the certificate:
Delete the certificate revocation list:
Select the certificate revocation list for the certificate you want to verify → press [CRL Details] → [Verify CRL].
Confirm the validity of the certificate with the displayed result.
For more information on the check result, see "Network/Security."
Press [OK].
To check the certificate authority, press [Serial No. List].
Select the certificate revocation list you want to delete → press [Delete].
Press [Yes].
4.
Press [OK] → [OK].
For instructions on how to install a certificate revocation list, see "Installing a Certificate File."
Up to 50 certificate revocation lists can be registered.
» Security » Key Pair and Server Certificate Settings for Encrypted SSL Communication » Verifying Certificate Validity Using Certificate Revocation List
08JK-27C
