A login service which supports this function is required. For more information, contact your local authorized Canon dealer.
You can use personal folders without specifying authentication information for each user when the conditions below are met. In that case, deselect [Use Auth. Info. of Each User].
When using the same authentication information for logging in to the machine and accessing the file server
When using a login service which supports Integrated Authentication
For information whether the login service you are using supports Integrated Authentication, contact your local authorized Canon dealer.
You can register user information from
[User Name]:
Enter the login user name for accessing folders designated by the login service.
[Password]:
Enter the password for accessing the folders designated by the login service.
The available protocol is SMB only.
The information for the personal folder obtained from the login service is displayed in [Host Name] and [Folder Path].
