Specifying Personal Folders
The personal folder is the destination which can be specified for each user. This setting is enabled only if you are managing users by login service, such as SSO-H. After specifying this setting, each user can select the personal folder as the destination for sending files.
The personal folder enables you to prevent information leakage which occurs during sending, such as to a wrong destination.
This section explains necessary settings you need to specify before using personal folders. For more information on sending files to personal folders, see "Setting Your Personal Folder as the Destination."
Select the specification method from the followings:
» Security » Authentication Method Settings for Sending Operations » Specifying Personal Folders
08JK-26R
