(Settings/Registration). The settings available for operation vary according to the type of administrator. This section describes the settings in
(Settings/Registration) that each administrator can operate.
(Settings/Registration) that each administrator can operate.|
For information on the types of administrators, see "Administrator Settings."
All users can set the settings in [Adjustment/Maintenance] (Settings/Registration).
: Only the administrator can change the settings.|
System Manager/System Administrator (Administrator)
Network Administrator (NetworkAdmin)
Device Administrator (DeviceAdmin)
[Restart Device]
[Paper Settings]
Paper Type Management Settings
[Display Settings]
Edit Puncher Unit Die Name
[Timer/Energy Settings]
Date/Time Settings
Time Format
Quick Startup Settings for Main Power
Restrict Auto Reset Time
[Network Settings]
TCP/IP Settings
IP Address Settings (IPv4)
IP Address Settings (IPv6)
DNS Settings (IPv4)
DNS Settings (IPv6)
WINS Settings
LPD Print Settings
RAW Print Settings
SNTP Settings
FTP Print Settings
WSD Settings
FTP PASV Mode
IPP Print Settings
Multicast Discovery Settings
HTTP Settings
WebDAV Server Settings
SSL Settings
Proxy Settings
Confirm Department ID PIN
IPSec Settings
NetWare Settings
AppleTalk Settings
SMB Server Settings
SNMP Settings
Dedicated Port Settings
Spooler
Startup Settings
Ethernet Driver Settings
IEEE802.1X Settings
Firewall Settings
IPv4 Address Filter
IPv6 Address Filter
MAC Address Filter
IP Address Block Log
[External Interface]
USB Settings
[Common Settings]
Print Settings
Copy Set Numbering Option Settings
Secure Watermark/Document Scan Lock Settings*
Generate File
Rights Management Server Settings
Document Scan Lock Operational Settings
Set Authentication Method
[Copy]
Select Color Settings for Copy
[Printer]
Restrict Printer Jobs
PDL Selection (Plug-n-Play)
[Send]
Common Settings
Confirm SSL Certificate for WebDAV TX
TX Report/Communication Management Report
TX Report - Attach TX Image to Report
TX Report - Attach Color TX Image to Report
Network Settings - E-Mail/I-Fax Settings
Confirm SSL Certificate for SMTP TX
Confirm SSL Certificate for POP RX
Communications Settings - E-Mail/I-Fax Settings
Limit New Destination
Only Send E-Mail to Myself
Only Send File to Personal Folder
Personal Folder Specification Method
TX Settings - Fax Settings
Fax TX Report/Fax Activity Report
Fax TX Report - Attach TX Image to Report
Set Line
PIN Code Access
Communications Settings-Fax Settings
Confirm Entered Fax Number
Allow Fax Driver TX
Remote Fax TX Settings
Remote Fax Settings
[Receive/Forward]
Common Settings
Divided Data RX Timeout/Always Send Notice for RX Errors
Handle Files with Forwarding Errors
Forwarding Settings
Memory Lock Settings
Fax Settings-RX Settings
RX Start Speed/RX Password
[Store/Access Files]
Settings for All Mail Boxes
Box Security Settings
Advanced Box Settings
Set Details
URI TX Settings
Delete Personal Space
Delete Shared Space
Save Operation Log
Network Settings
Protocol for External Reference
Set SSL Certificate Confirmation for Network Access
Memory Media Settings
[Secure Print]
[Address Book PIN]
[Manage Address Book Access Numbers]
[Address Book Export Settings]
[Register LDAP Server]
[Register/Edit LDAP Search]
[Acquire Remote Address Book]
[Make Remote Address Book Open]
[User Management]
System Manager/Contact Person Information Settings
Department ID Management
[Device Management]
Device Information Settings
Limit Functions When Security Key is Off
Certificate Settings
Key and Certificate Settings
CA Certificate Settings
Certificate Revocation List (CRL) Settings
Display Job Status Before Authentication
Display Log
Audit Log Retrieval
Export/Clear Audit Log
Encryption Method Settings
[License/Other]
Message Board/Support Link
Remote UI Settings
Remote Operation Settings
MEAP Settings
Register/Update Software
[Data Management]
Hard Disk Data Complete Deletion
Import/Export All
Import
Export
Import/Export Results
Import/Export Individually
Address Lists
Device Settings (Forwarding Settings, Address Book, Send Function Favorite Settings)
Web Access Favorites
Printer Settings
Paper Information
Back Up/Restore Settings
Backup Location Settings
Auto Backup Settings
Back Up
Restore
Back Up/Restore Log
