Send Features of the WSD Scan
This section describes how to use the send features of the WSD Scan.
You can use the Push Scan function only in the following conditions:
Paper size:
LTR
Color mode:
Color
Resolutions:
300 dpi (fixed setting)
File format:
BMP, JPEG, PNG, TIFF
Place your originals.
You cannot scan 2-sided originals even if you are using a feeder. Place 1-sided originals.
The available scanning size is LTR. For example, if you set 11" x 17" originals, only LTR size is scanned.
For instructions on placing originals, see "Placing Originals."
Press [WSD Scan].
Select the destination.
The computers, which are in the same domain and are equipped with the driver for WSD Scan functions, are listed.
4.
Press [Start].
If the destination [Scan to "computer name"] is selected:
If the destination other than [Scan to "computer name"] is selected:
A screen prompting you to select a program is appears. Scanning is complete after selecting the program.
The Windows Explorer starts and a scanned file is displayed.
Up to 40 destinations are displayed.
You cannot use [Send for OCR to "computer name"] when selecting the destination. If you want to use the OCR function, see "Searchable PDF/XPS/OOXML."
» Scanner » WSD Scan » Send Features of the WSD Scan
08JK-1EK
