Recalling a Personal Button/Shared Button
You can recall registered Personal buttons/Shared buttons. This section describes the procedure for using Personal buttons.
Press (Quick Menu).
Select [Personal] → press the button you want to use.
Press [Yes].
If you set <Display Confirmation Screen When Recalling> to 'Off' for the recall settings when registering in the Quick Menu, the confirmation dialog box is not displayed before processing the settings registered in the button. (See "Registering a Personal Button/Shared Button.")
For instructions on registering a Personal button/Shared button, see "Registering a Personal Button/Shared Button."
The destinations registered in the one-touch buttons on the Quick Menu of the client machine are not updated even if those registered in the one-touch buttons of a server machine are updated. Confirm if the destination is updated when you cannot send to the registered destinations.
» Quick Menu » Using the Quick Menu from the Machine » Recalling a Personal Button/Shared Button
08JK-1FJ
