For information on the Scan and Send function, see "Scan and Send."
If you select [Device Login Auth. Info.] for [Info. Used for File TX/Browsing Auth.] in [Function Settings] (Settings/Registration), a password for a file destination is not stored in a personal button or a shared button in the Quick Menu. For more information on settings for [Info. Used for File TX/Browsing Auth.], see "Specifying Authentication Method for File Server."
You can select whether to include the following passwords when registering settings in a Personal button or Shared button in the Quick Menu:
A password required to access to the file server when registering a file destination
A password required to login to the Rights Management Server when generating a PDF file compatible with the Rights Management Server
If you want to recall the registered button without entering a password, include a password when registering.
If you want to set password in the settings stored in the registered button, as you often import settings in a Personal button or Shared button to another machine and you want to prevent users from pretending to be other users, exclude a password when registering.
The number of Personal buttons that can be registered may be less than the maximum, depending on the memory usage of the Quick Menu function.
For instructions on using a Personal button/Shared button, see "Recalling a Personal Button/Shared Button."
If authentication is not set, the Personal buttons are not displayed.
