Changing the Default Settings for the Fax Function
You can change the default settings for [Fax].
This mode can be set when the Fax function is available for use. For information on the optional products required to use the Fax function, see "
Optional Products Required for Each Function (imageRUNNER ADVANCE C9280 PRO/C9270 PRO)" or "
Optional Products Required for Each Function (imageRUNNER ADVANCE C7270/C7260)."
Press
(Settings/Registration).
To register a favorite settings button, set the Fax mode in advance.
Press [Function Settings] → [Send] → [Fax Settings].
Press [Change Default Settings].
4.
Press [Register].
5.
Press [Yes].
6.
Press [Close].
Initializing the Default Settings for the Fax Function
Press
4.
Press [Initialize].
5.
Press [Yes].
