Changing/Initializing the Default Settings for the Copy Function
You can change/initialize the default settings for [Copy].
This mode can be set when the Copy function is available for use. For information on the optional products required to use the Copy function, see "
Optional Products Required for Each Function (imageRUNNER ADVANCE C9280 PRO/C9270 PRO)" or "
Optional Products Required for Each Function (imageRUNNER ADVANCE C7270/C7260)."
Changing the Default Settings for the Copy Function
Press
(Settings/Registration).
Press [Function Settings] → [Copy] → [Change Default Settings].
Press [Register].
The current copy settings are set as the default settings.
4.
Press [Yes].
Press
Press [Initialize].
4.
Press [Yes].
