This mode cannot be used with jobs without a job ticket.
] or [
You can cancel a selection by selecting the page range again.
To cancel all page ranges, press [Clear Selection]. (When there are no selected page ranges, [Clear Selection] changes to [Select All].)
If multiple page ranges are selected and the settings of each page range are different, [Mixed] is displayed for [Output Paper Size], and [Each Partition] or [Apply Settings for Each Partition] is displayed for the other settings.
If you press
, the detailed information of the selected paper is displayed. |
Paper that is registered from [Duplicate] with default settings.
Paper that is registered from [Duplicate] with changed settings.
[All]:
Displays all paper types.
[Standard Type]:
Displays only paper types under the Standard category.
[Custom Type]:
Displays only paper types under the Custom Paper category.
If you enter a value other than 0, you can switch between the positive and negative margin widths by pressing [±].
(numeric keys) → press [OK].
For more information on the modes which cannot be set in combination with this mode, see"Unavailable Combination of Functions."
