In case C, the Import All function may not be enabled, depending on the model of the destination machine for importing. For more information, contact your local authorized Canon dealer.
In case B and C, some setting values may not be imported when performing the Import All function under the following condition:
The optional equipment required to specify the setting information is not attached to the destination machine for importing.
Setting Information
Case A
Case B
Case C
Preferences
Paper Settings
Paper Settings
Register Custom Size
Display Settings
Default Screen after Startup/Restoration
Default Screen (Status Monitor/Cancel)
Copy Screen Display Settings
Display Fax Function
Store Location Display Settings
Language/Keyboard Switch On/Off
Use Keyboard Shift Lock Feature
Display Remaining Paper Message
No. of Copies/Job Duration Status
Display Original Scanning Cleaning Area
Select Paper Screen Priority
mm/Inch Entry Switch
ID/User Name Display On/Off
Display Remaining Toner Error Message
Setting Information
Case A
Case B
Case C
Preferences
Timer/Energy Settings
Date/Time Settings
Time Format
Quick Startup Settings for Main Power
Auto Reset Time
Restrict Auto Reset Time
Function After Auto Reset
Auto Sleep Time
Sleep Mode Energy Use
Auto Sleep Weekly Timer
Sleep Mode Exit Time Settings
Setting Information
Case A
Case B
Case C
Preferences
Network
Confirm Network Connection Set. Changes
TCP/IP Settings
IPv4 Settings
Use IPv4
IP Address Settings
IP Address
Subnet Mask
Gateway Address
DHCP
RARP
BOOTP
DHCP Option Settings
IPv6 Settings
Use IPv6
Stateless Address Settings
Manual Address Settings
Use DHCPv6
DNS Settings
DNS Server Address Settings
DNS Host/Domain Name Settings
DNS Dynamic Update Settings
WINS Settings
LPD Print Settings
RAW Print Settings
SNTP Settings
FTP Print Settings
WSD Settings
Use FTP PASV Mode
Multicast Discovery Settings
Use HTTP
Use WebDAV Server
Proxy Settings
NetWare Settings
AppleTalk Settings
SMB Server Settings
SNMP Settings
Dedicated Port Settings
Use Spool Function
Startup Settings
Ethernet Driver Settings
Firewall Settings
Setting Information
Case A
Case B
Case C
Preferences
External Interface
USB Settings
Accessibility
Key Repetition Settings
Reversed Display (Color)
Adjustment/Maintenance
Adjust Image Quality
Correct Density
Full Color Printing Vividness Settings
Fine Adjust Zoom
Setting Information
Case A
Case B
Case C
Function Settings
Common
Paper Feed Settings
Print Settings
Text/Photo Priority When ACS Is Set to Black
Output Report Default Settings
Superimpose Image Quality Priority
Register Characters for Page No./Watermark
Secure Watermark/Document Scan Lock
Scan Settings
Streak Prevention
Feeder Black Scan Speed/Image Qlty. Priority
LTRR/STMT Original Selection
Remote Scan Gamma Value
Auto Online
Auto Offline
Generate File
High Compression Image Quality Level
Compact PDF Settings for Text Original
OCR (Text Searchable) Settings
Trace & Smooth Settings
OOXML Settings
Include Background Images in Word File
Specify Minimum PDF Version
Format PDF to PDF/A
Optimize PDF for Web
256-bit AES Settings for Encrypted PDF
Rights Management Server Settings
Document Scan Lock Operational Settings
Set Authentication Method
Setting Information
Case A
Case B
Case C
Function Settings
Copy
Auto Collate
Auto Orientation
Select Color Settings for Copy
Send
Common Settings
E-Mail/I-Fax Settings
Register Unit Name
Communication Settings
SMTP RX
POP
SMTP Server
E-Mail Address
POP Server
POP Login Name
POP Password
POP Interval
Authent./Encryption
Confirm SSL Certificate for SMTP TX
Confirm SSL Certificate for POP RX
Maximum Data Size for Sending
Default Subject
Specify Authentication User Dest. to Reply
Set Authentication User Dest. to Sender
Allow Unregistered Users to Send E-Mail
Full Mode TX Timeout
Print MDN/DSN upon Receipt
Use Send via Server
Allow MDN Not via Server
Restrict TX Destination Domain
Autocomplete for Entering E-Mail Addresses
Fax Settings
Default Screen
Change Default Settings
Register Options Shortcuts
Register Sender Name (TTI)
Use Auth. User Name as Sender Name
ECM TX
Set Pause Time
Auto Redial
Check Dial Tone Before Sending
Fax TX Report
Fax Activity Report
Set Line
Line 1 to Line 4
Register Unit Telephone Number
Register Unit Name
Select Line Type
Select TX Line
TX Start Speed
PIN Code Access
Confirm Entered Fax Number
Allow Fax Driver TX
Remote Fax TX Settings
Remote Fax Settings
Receive/Forward
Common Settings
Fax Settings
Store/Access Files
Mail Box Settings
Advanced Box Settings
Network Settings
Memory Media Settings
Secure Print
Simple Authentication Settings
Only Allow Encrypted Print Jobs
Setting Information
Case A
Case B
Case C
Set Destination
Change Default Display of Address Book
Address Book PIN
Manage Address Book Access Numbers
Include Pswd. When Exporting Address Book
Register LDAP Server
Auto Search When Using LDAP Server
Change Default LDAP Search Conditions
Register/Edit LDAP Search Conditions
Acquire Remote Address Book
Acquire Address Book
Remote Address Book Server Address
Communication Timeout
Fax TX Line Auto Select Adjustment
Make Remote Add. Book Open
Make Address Book Open
Setting Information
Case A
Case B
Case C
Management Settings
Device Management
Device Information Settings
Device Information Delivery Settings
Register Destinations
Set Auto Delivery
Restrict Receiving Device Information
Restrict Receiving for Each Function
Report Settings
Display Job Status Before Authentication
Display Log
Audit Log Retrieval
Format Encryption Method to FIPS 140-2
License/Other
Message Board/Support Link
Remote Operation Settings
Data Management
Back Up/Restore Settings
HDD Data Complete Deletion
Setting Information
Case A
Case B
Case C
Function Settings
Receive/Forward
Common Settings
Store/Access Files
Mail Box Settings
Access Stored Files
Mail Box (Print)
Color Balance (Options)
Scan and Store
Advanced Box (Scan)
Custom (Scan Size)
Setting Information
Case A
Case B
Case C
Management Settings
User Management
System Manager Information Settings
Department ID Management
Register PIN
Setting Information
Case A
Case B
Case C
Main Menu Settings
Setting File
Setting Information
Case A
Case B
Case C
Function Settings
Copy
Register/Edit Favorite Settings
Register Options Shortcuts (Regular Copy)
Register Options Shortcuts (Express Copy)
Send
Common Settings
Fax Settings
Store/Access Files
Common Settings
Copy Basic Features Screen
Setting Information
Case A
Case B
Case C
Set Destination
Rename Address List
Register One-Touch
Setting Information
Case A
Case B
Case C
Function Settings
Receive/Forward
Common Settings
Setting Information
Case A
Case B
Case C
Quick Menu Settings
Button File
Setting Information
Case A
Case B
Case C
Workflow Composer
Flow Data File
Operation Setting File
MEAP User Setting Information
Data
MEAP Application Setting Information
Data
Setting Information
Case A
Case B
Case C
Preferences
Paper Settings
Paper Type Management Settings
Setting Information
Case A
Case B
Case C
User Access Control for Advanced Box
User List
Integrated Authentication Settings
Authentication/Operation Log Management
Setting Information
Case A
Case B
Case C
Web Access Settings*
Favorites
Settings
