Staple Finisher-J1/Booklet Finisher-J1 (Optional)
If a paper jam occurs inside the finisher or puncher, a screen prompting you to remove the jammed paper appears on the touch panel display. Check the location of the paper jam, and follow the procedure described below, while referring to the directions that appear on the touch panel display, to remove the jammed paper.
The Staple Finisher-J1, Booklet Finisher-J1, and Buffer Pass Unit-G1 are optional products.
» Problem Solving » Clearing Paper Jams » Staple Finisher-J1/Booklet Finisher-J1 (Optional)
06RH-0J9
