Cassette Feeding Unit-AD2 (Optional)
Check the location of the paper jam, and follow the procedure described below, while referring to the directions that appear on the touch panel display, to remove the jammed paper.
The Cassette Feeding Unit-AD2 is an optional product.
If the Paper Deck Unit-B2 is attached, move the paper deck unit away from the main unit before proceeding with this procedure.
Remove any paper jammed in the lower right cover of the cassette feeding unit.
1. Open the lower right cover of the cassette feeding unit.
2. Remove any jammed paper.
Remove any paper jammed in the cassette feeding unit.
1. Press the open button of the paper drawer that is feeding the paper.
2. Grip the handle, and pull out the paper drawer until it stops.
3. Remove any jammed paper.
Gently push the paper drawer back into the machine until it clicks into place in the closed position.
CAUTION
When returning the paper drawer to its original position, be careful not to get your fingers caught, as this may result in personal injury.
4.
Close the lower right cover of the cassette feeding unit.
CAUTION
When closing the covers, be careful not to get your fingers caught, as this may result in personal injury.
Gently close the covers until they click into place in the closed position.
If the Paper Deck Unit-B2 was moved away from the main unit, reconnect it to the main unit.
5.
Follow the instructions on the screen.
The screen indicating the directions on how to clear the paper jam is displayed repeatedly until the paper jam is cleared.
» Problem Solving » Clearing Paper Jams » Paper Sources » Cassette Feeding Unit-AD2 (Optional)
06RH-0J6
