If a paper jam occurs in a paper drawer or paper deck unit, a screen prompting you to remove the jammed paper appears on the touch panel display. Check the location of the paper jam, and follow the procedure described below, while referring to the directions that appear on the touch panel display, to remove the jammed paper.
The Cassette Feeding Unit-AD2 and Paper Deck Unit-B2 are optional products.
If paper is loaded in the multi-purpose tray, remove the loaded paper.
