Category Top
Overview of This Function
Overview of Login Services
Login Screens
SSO-H (Single Sign-On H)
Login Screens
System Requirements
Before Logging In to SSO-H
Logging In to SMS
Logging Out from SMS
Managing Applications
Uninstalling Applications
Managing Application Licenses
Installing Applications
Login Service Selection
Uninstalling a Login Service
Confirming System Information
Confirming Application Data
Confirming License Files
Changing the Password
Managing Application Logs
Logging In to SSO-H
Menu for Administrators
Registering/Editing User Data for LDAP Server Authentication
Setting the SSO-H
Setting Password Restrictions
Setting the Lockout Function
Menu for General Users
SDL Format
NetSpot Accountant 3.x Format
NetSpot Accountant 4.x Format
Troubleshooting
Other Trouble
Top » MEAP » Managing Applications » Managing Application Licenses
06RH-214
You can add, disable, or delete license files for installed applications.
Once you have deleted the disabled license file, you cannot download it from the machine.
Disabling a license file must be performed after stopping the application you want to disable. You cannot disable a license file if the application has not been stopped.
When a disabled license file is generated, the status of that license file becomes <Uninstalled> and the application becomes unusable.
Adding License Files
You can increase counter values and extend terms of validity by adding a license file.
Click [MEAP Application Management].
Click the name of the application to add a license file for.
Click [License Management].
4.
Click [Browse…].
5.
In the dialog box that appears, select the license file that you want to install → click [OK].
6.
Click [Install].
The message <Installing... Please wait.> appears.
7.
Click [Yes].
Installation will start after the message <Installing... Please wait.> appears again.
If the license of an application is expired or disabled, it is necessary to restart (stop and start) the application after the new license file is added.
Disabling License Files
You must disable a license file before deleting or downloading it.
Click the name of the application to disable the license file for.
4.
Click [Disable].
5.
Click [Yes].
Downloading/Deleting Disabled License Files
If you want to uninstall an application, you must first delete the license file. Also, if you want to back up before deleting, download and store the license file on your computer.
Click the name of the application to download or delete the license file for.
To download the license file:
To delete the license file:
Select [Download].
Follow the instructions on the screen and specify the location to store the file.
Select [Delete].
Click [Yes].
The downloaded or disabled license file can be reinstalled to the same machine.
Only disabled license files can be downloaded or deleted.
If you want to delete a license file, depending on the license file, you may need to download the file after disabling it.
