on the top right of the screen.
on the top right of the screen, the following screen is displayed. Select settings from the displayed screen and set the display of the Main Menu screen.
to select the number of buttons and the layout to be displayed. You can display 3 to a maximum of 16 buttons on one screen.
appears on the Main Menu screen.
Optional Products Required
Functions Displayed on the Main Menu Screen
Fax Board or Remote Fax Kit (activated)
Web Access Software (activated)
To specify the settings of the Main Menu screen, you must log in to the machine as an administrator. As a default, system manager settings (System Manager ID/System PIN) are set on the machine. Thus, the administrator must log in by entering the System Manager ID and the System PIN on the Settings/Registration screen. The default setting for both the System Manager ID and System PIN is '7654321'.
If the number of function buttons exceeds the number of buttons in the layout specified for <Main Menu Button Display Settings>, the excess buttons are displayed after page 2 of the Main Menu screen. A maximum of 16 buttons can be displayed on the Main Menu screen.
If you press [Show All] on the Main Menu screen, all buttons are displayed in the default order, even if you have altered the layout of the buttons. To return to the customized screen, press [Show All] again.
For more information on [Language/Keyboard Switch], see "Enabling the Language/Keyboard Switch."
For more information on [Auto Adjust Gradation], [Paper Settings], and [Paper Type Management Settings], see "Automatic Gradation Adjustment," "Registering the Paper Size and Type for a Paper Source," and "Registering/Editing Custom Paper Types."
If you register a web page in Favorites, you can hide the [Web Access] button on the Main Menu screen. (See "Privacy Policy and Regulations Settings.")
Line breaks used when registering web pages are shown in the name of web page buttons on the Main Menu screen.
