Overview of This Function
You can print files stored in the following two types of storage:
Network
Memory Media
To print a stored file, press [Access Stored Files] on the Main Menu screen → specify the location where the desired file is stored.
A network location refers to memory (Advanced Box) of another imageRUNNER ADVANCE series machine on the network that can be accessed by this machine.
By selecting the Advanced Box of another imageRUNNER ADVANCE series machine from [Network], you can scan a document with this machine, and store it in the Advanced Box of the other imageRUNNER ADVANCE series machine. You can also use this machine to print files stored in another imageRUNNER ADVANCE series machine on the network.
For more information on the optional products required to preview/print PDF or XPS files from this machine, see
"Optional Products Required for Each Function."
For instructions on specifying the settings for using a network, see
"Network Settings."
Memory media is a storage location that can be used by connecting USB memory to the USB port of the machine. You can scan a document with this machine and store it in memory media in various file formats that can be used on your computer. You can also print files stored in memory media on this machine at any time with your desired print settings.
If the USB Device Port-E2 and Multimedia Reader/Writer-A2 are installed, you can use SD cards, Memory Sticks, CF cards, and Microdrives as memory media. For more information, see
"USB Device Port-E2" and
"Multimedia Reader/Writer-A2."
For instructions on inserting/removing memory media, see
"Inserting and Removing Memory Media."
The following memory media file system is supported:
Type: USB memory
File System: FAT32
Devices such as the following are not supported:
Memory media with security functions
Memory media that does not meet the USB specification
Memory card readers connected via USB
Usage methods such as the following are not supported:
Connecting memory media via an extension cable
Connecting memory media via a USB hub
Some memory media cannot be used.
Types of Network/Memory Media Icons
The table below shows the types of files that can be used in the Advanced Box of another machine on the same network and memory media, as well as the icons used for each file type.
Icon
Type of File
JPEG file
TIFF file
PDF file
XPS file
