Function
Optional Product Required
Notes
Feeding Envelopes from Paper Source
Envelope Feeder Attachment-D1
Adding Paper Sources
Cassette Feeding Unit-AF1
Collate/Group/Offset/Staple
Restrictions for the Above Modes
Inner Finisher-F1
The Inner Finisher-F1 cannot be used with the Inner 2Way Tray-F1, Staple Finisher-M1, or Booklet Finisher-M1.
Staple Finisher-M1 or Booklet Finisher-M1
Buffer Pass Unit-K1
Inner Finisher-F1 and Copy Tray-J1 cannot be attached to the Staple Finisher-M1 or Booklet Finisher-M1.
Saddle Stitch Booklet, Saddle Fold
Booklet Finisher-M1
Buffer Pass Unit-K1
Additional Output Tray for the Inner Finisher
Inner Finisher Additional Tray-A1
Inner Finisher-F1
Additional Output Tray under the Scanner Unit
Inner 2Way Tray-F1
Inner 2Way Tray-F1 cannot be used with the Inner Finisher-F1, Staple Finisher-M1, or Booklet Finisher-M1.
Additional Output Tray on the Right Side of the Machine/Collate/Group/Rotate 90 Degrees
Copy Tray-J1
Copy Tray-J1 cannot be used with the Staple Finisher-M1 or Booklet Finisher-M1.
Department ID Management Using Card
Copy Card Reader-F1
Additional USB Port
USB Device Port-E2
Multimedia Reader/Writer
Multimedia Reader/Writer-A2
USB Device Port-E2
Machine Function
Required
Limitations
PCL Print
PCL Printer Kit
PS Print
PS Printer Kit
Direct Print (PDF)/Printing PDF files stored in memory media or the Advanced Box of another imageRUNNER ADVANCE machine on the network.
PS Printer Kit or Direct Print Kit (for PDF/XPS)
If the PS Printer Kit is used, the Direct Print Kit (for PDF/XPS) is not required.
Direct Print (XPS)
Barcode Print
Barcode Printing Kit
PCL Printer Kit
Fax Function
Memory Sending/Register Sender Name/Use Authentication User Name as Sender Name/Confirm Entered Fax Numbers/Subaddress Sending/Fax TX Report/Fax Activity Report/Fax Multi TX Report/Fax User Data List/Set Line/Tone/Pause
Super G3 FAX Board or Remote Fax Kit
To use these functions on the Remote Fax Kit, the imageRUNNER ADVANCE series (Remote Fax server machine) with Super G3 FAX Board must correctly be connected with this machine.
To use [Select Line] , you must have more than one telephone line.
Fax Function
Display Fax Function/Direct Sending/Register Unit Telephone Number/Register Unit Name/Volume Settings/Allow Fax Driver TX/ECM TX/Auto Redial/Send Start Settings/PIN Code Access/Memory Receiving/ECM RX/Subaddress Receiving/Receive Start Speed/Receive Password/Forwarding Settings/Fax RX Report/Confidential Fax Inbox RX Report/Select TX Line/Select Line Type/Onhook/Manual Sending/Check Dial Tone Before Sending/Pause Time
Super G3 FAX Board
Functions Related to Remote Fax
(Settings as a server machine)
Remote Fax Settings
Super G3 FAX Board
Remote Fax Function
(Settings as a client machine)
Send Remote Fax/Send Remote Fax Settings
Remote Fax Kit
To use these functions, the machine with Super G3 FAX Board must correctly be connected with this machine.
Fax Function with 2 Lines
Super G3 2nd Line Fax Board
Super G3 FAX Board
The following functions are only available with Line 1 (the standard line):
Fax/Tel Auto Switch
Remote RX
Audible Tones
On-Hook
Trace & Smooth PDF
Universal Send Advanced Feature Set
Reader Extensions PDF
Encrypted PDF
Universal Send Security Feature Set
Device Signature PDF/XPS
User Signature PDF/XPS
Universal Send Digital User Signature Kit
Secure Watermark
Secure Watermark
HDD Data Encryption
HDD Data Encryption Kit
Removable HDD Management
Removable HDD Kit
The Removable HDD Kit is only used for removing the standard-equipped 80 GB hard disk of the machine.
Restricting Document Duplication/Track Users
Document Scan Lock Kit
Embedding and analyzing TL code are available.
Viewing Web Pages
Web Access Software
Encrypted Secure Printing
Encrypted Secure Print Software
Registering Combinations of Functions
Workflow Composer
Voice Guidance
Voice Guidance Kit/Voice Operation Kit
Voice Operation
Voice Operation Kit
Operation of the Machine from Computer
Remote Operator's Software Kit
The Super G3 FAX Board and Remote Fax Kit cannot be used at the same time.
