Cause
You have no permission to access the folder/file, or the folder/file may be deleted in other operations.
Remedy
Set to permit access to the folder on the server machine. Otherwise, contact your server administrator.
Cause
The store location could not be found due to one of the following possible causes:
The Advanced Box of another machine on the network was deleted while it was being accessed.
Memory media was removed while it was being accessed.
Remedy
Check that the memory media is inserted or that the Advanced Box of another machine on the network is available.
Cause
When you tried to access the file, the full pathname (file/folder names indicating the store location) was too long.
Remedy
Shorten the folder and file names, or change the store location.
Cause
An unexpected system error occurred.
Remedy
Contact your local authorized Canon dealer.
Cause
The network is not connected.
Remedy
Check the status of the network.
Cause
This operation cannot be performed because another operation is running.
Remedy
Wait until the other operation is finished, then try again.
Cause
The network settings are incorrect.
Remedy
Check the network settings. (See "Network Settings.")
Cause
The number of stored passwords for the login user exceeded the maximum number.
Remedy
Erase unnecessary password information.
Cause
There is a folder in the selected directory with the same name as the name you entered on the New Folder screen.
Remedy
Assign a different name to the folder.
Cause 1
Memory media is write prohibited.
Remedy
Cancel write prohibition on the memory media.
Cause 2
[Prohibit Writing from External] in the store location's [Function Settings] (Settings/Registration) is set to 'On'.
Remedy
Set [Prohibit Writing from External] in the store location's [Function Settings] (Settings/Registration) to 'Off'.
Cause
You tried to store data that exceeded the store location memory capacity.
Remedy
Perform the operation again after deleting unwanted files from the store location, or change the store location.
Cause
Invalid characters are included in the folder or file name.
Remedy
Enter the name again using valid characters.
Cause
Remedy
Cause
You do not have permission to access the folder.
Remedy
Change the settings on the file server to enable access to the folder, or contact the server administrator.
Cause
You tried to store more than the capacity of the other machine's Advanced Box (100,000 files/ folders), or more than the capacity of the designated destination folder (1,000 files/folders).
Remedy
Perform the operation again after deleting unwanted files from the store location folder, or change the store location.
Cause
The file is being accessed by another user.
Remedy
Wait until the other user finishes accessing the file.
Cause
Writing failed because the folder is read-only.
Remedy
In the folder attributes, cancel "read-only."
Cause
The file could not be saved because a file with the same name already exists.
Remedy 1
Change the filename and save the file again.
Remedy 2
Change the store location and save the file again.
Cause
The Network Place may be deleted.
Remedy
Check if the Network Place is deleted.
Cause
The number of trials allowed for using the optional functions is reached the upper limit.
Remedy
If you wish to continue using these functions, contact your local authorized Canon dealer.
Cause
Since the available memory of the store location (memory media or folder) is full, the scanned data could not be saved.
Remedy 1
Wait a while, and try performing the operation again.
Remedy 2
Change the resolution and file format, then perform the operation again.
Remedy 3
Delete unnecessary data from the store location to make more memory available, and then perform the operation again.
Cause
Scanning could not be performed because the maximum number of prints set in Department ID Management was exceeded.
Remedy
Contact your System Manager.
Cause
The job was canceled because the memory for saving temporary data became full.
Remedy
Cause
Since the available memory of the store location is full, the scanned data could not be saved.
Remedy 1
Remedy 2
Cause
When scanning, after the scanning limit of 999 pages was reached, further pages were added to the scan.
Remedy
Scanned pages are stored. To store more pages, load the pages that have not been stored again and then store them under a different name.
Cause
After a paper jam occurred in the feeder and the originals were once again loaded during scanning, the number of loaded pages that are detected is different from when the job was first loaded.
Remedy
Load the originals once more, then press the [Start] key.
Cause
The size of the scanned data is too large.
Remedy 1
Remedy 2
Reduce the number of pages to scan, then perform the operation again.
Cause
You tried to create a PDF file with a digital certificate using a corrupted certificate or key.
Remedy
Check if the certificate or key is corrupt.
Cause
The expiration date of the certificate has expired.
Remedy
Confirm the expiration date for the certificate, and the date/time set on the machine.
Cause
Remedy
Change the store location to save the file.
Cause
Storing cannot be performed because there are too many jobs waiting to be stored.
Remedy
Perform the operation again when the other jobs are complete.
Cause 1
The URL for the Rights Management Server is incorrect.
Remedy
Check the [Rights Management Server Settings]. (See "Setting a Rights Management Server.")
Cause 2
Cannot start the Rights Management Server.
Remedy
Check the Rights Management Server.
Cause 3
Remedy
Cause 1
[Optimize PDF for Web] is set to 'On', and PDF modes that cannot be set are selected in forwarding settings. (See "Optimizing PDF for Web.")
Remedy
Set only one of the following: Device Signature, User Signature, or Reader Extensions. Alternatively, set [Optimize PDF for Web] to 'Off'.
Cause 2
[Format PDF to PDF/A] is set to 'On', and PDF modes that cannot be set are selected in forwarding settings. (See "Formatting PDF Files to PDF/A.")
Remedy
Cancel the Encrypt and Visible Signatures settings. Alternatively, set [Format PDF to PDF/A] to 'Off'.
Cause
Printing was interrupted because the file size exceeded the upper limit for printing (2 GB).
Remedy
Reduce the file size, and perform the operation again.
Cause
Printing could not be performed because the number of print jobs exceeded the upper limit.
Remedy
Cause
The memory required for printing is insufficient.
Remedy
After canceling the print job, first reduce the amount of data and pages to be printed, and then try printing again.
Cause
Printing could not be performed because the maximum number of prints set in Department ID Management was exceeded.
Remedy
Cause
Remedy
Cause 1
An incorrect password was entered.
Remedy
Enter the correct password, and perform the job again.
Cause 2
The PDF file is set so that it cannot be printed.
Remedy
Check the PDF file settings.
Cause
You tried to print data that is not supported by this machine.
Remedy
Use file formats that are supported by this machine.
Cause
An error occurred while processing the print data.
Remedy
To print the remaining pages, press [OK].
