(Settings/Registration).
(Settings/Registration). |
Depending on the type of MEAP application that uses device such as a keyboard or card reader, you may need to set this setting to 'On'. To check whether you need to set this setting to 'On', see the manual for the MEAP application you are using, or contact your local authorized Canon dealer.
Depending on the type of MEAP application that uses USB external memory device, you may need to set this setting to 'On'. To check whether you need to set this setting to 'On', see the manual for the MEAP application you are using, or contact your local authorized Canon dealer.
Changes are only effective after you restart the machine (the main power switch is turned OFF, and then back ON). For instruction on restarting (turning the main power switch OFF and then ON) the machine, see "Main Power and Energy Saver Key."
