In case C, the Import All function may not be enabled according to the model for importing. For more information, contact your local authorized Canon dealer.
In case B and C, even if you perform the Import All function under the following condition, some values may not be imported.
As for the settings information displayed when the optional equipment is attached to the machine, the relevant optional equipment is not attached to the machine for importing
Setting Information
Case A
Case B
Case C
Preferences
Paper Settings
Paper Settings
Register Custom Size
Display Settings
Default Screen after Startup/Restoration
Default Screen (Status Monitor/Cancel)
Display Fax Function
Store Location Display Settings
Language/Keyboard Switch On/Off
Use Keyboard Shift Lock Feature
Display Remaining Paper Message
No. of Copies/Job Duration Status
Display Original Scanning Cleaning Area
Paper Type Selection Screen Priority
mm/Inch Entry Switch
ID/User Name Display On/Off
Display Remaining Toner Error Message
Setting Information
Case A
Case B
Case C
Preferences
Timer/Energy Settings
Date/Time Settings
Time Format
Quick Startup Settings for Main Power
Auto Reset Time
Restrict Auto Reset Time
Function After Auto Reset
Auto Sleep Time
Sleep Mode Energy Use
Auto Sleep Weekly Timer
Sleep Mode Exit Time Settings
Setting Information
Case A
Case B
Case C
Preferences
Network
Confirm Network Connection Set. Changes
TCP/IP Settings
IPv4 Settings
Use IPv4
IP Address Settings
IP Address
Subnet Mask
Gateway Address
DHCP
RARP
BOOTP
DHCP Option Settings
IPv6 Settings
Use IPv6
Stateless Address Settings
Manual Address Settings
Use DHCPv6
DNS Settings
DNS Server Address Settings
DNS Host/Domain Name Settings
DNS Dynamic Update Settings
WINS Settings
LPD Print Settings
RAW Print Settings
SNTP Settings
FTP Print Settings
WSD Settings
Use FTP PASV Mode
Multicast Discovery Settings
Use HTTP
Use WebDAV Server
Proxy Settings
NetWare Settings
AppleTalk Settings
SMB Server Settings
SNMP Settings
Dedicated Port Settings
Use Spool Function
Startup Settings
Ethernet Driver Settings
Firewall Settings
Setting Information
Case A
Case B
Case C
Preferences
External Interface
USB Settings
Accessibility
Key Repetition Settings
Reversed Display (Color)
Adjustment/Maintenance
Adjust Image Quality
Correct Density
Full Color Printing Vividness Settings
Fine Adjust Zoom
Setting Information
Case A
Case B
Case C
Function Settings
Common
Paper Feed Settings
Print Settings
Text/Photo Priority When ACS Is Set to Black
Output Report Default Settings
Register Characters for Page No./Watermark
Secure Watermark/Document Scan Lock
Scan Settings
Streak Prevention
Feeder Black Scan Speed/Image Quality Priority
LTRR/STMT Original Selection
Remote Scan Gamma Value
Auto Online
Auto Offline
Generate File
High Compression Image Quality Level
Compact PDF Settings for Text Original
OCR (Text Searchable) Settings
Trace & Smooth Settings
OOXML Settings
Include Background Images in Word File
Specify Minimum PDF Version
Format PDF to PDF/A
Optimize PDF for Web
256-bit AES Settings for Encrypted PDF
Rights Management Server Settings
Document Scan Lock Operational Settings
Set Authentication Method
Setting Information
Case A
Case B
Case C
Function Settings
Copy
Auto Collate
Auto Orientation
Select Color Settings for Copy
Send
Common Settings
E-Mail/I-Fax Settings
Fax Settings
Receive/Forward
Common Settings
Fax Settings
Store/Access Files
Network Settings
Memory Media Settings
Secure Print
Simple Authentication Settings
Only Allow Encrypted Print Jobs
Setting Information
Case A
Case B
Case C
Set Destination
Change Default Display of Address Book
Address Book PIN
Manage Address Book Access Numbers
Include Pswd. When Exporting Address Book
Register LDAP Server
Auto Search When Using LDAP Server
Register/Edit LDAP Search Conditions
Acquire Remote Address Book
Acquire Address Book
Remote Address Book Server Address
Communication Timeout
Fax TX Line Auto Select Adjustment
Make Remote Address Book Open
Make Address Book Open
Setting Information
Case A
Case B
Case C
Management Settings
Device Management
Device Information Settings
Device Information Delivery Settings
Register Destinations
Set Auto Delivery
Restrict Receiving Device Information
Restrict Receiving for Each Function
Report Settings
Display Job Status Before Authentication
Display Log
Format Encryption Method to FIPS 140-2
Data Management
Back Up/Restore Settings
Delete Existing Data Settings
Setting Information
Case A
Case B
Case C
Function Settings
Receive/Forward
Set/Register Confidential Fax Inboxes
Memory RX Inbox PIN
Setting Information
Case A
Case B
Case C
Management Settings
User Management
System Manager Information Settings
Department ID Management
Register PIN
Setting Information
Case A
Case B
Case C
Main Menu Settings
Setting File
Setting Information
Case A
Case B
Case C
Function Settings
Copy
Register/Edit Favorite Settings
Change Default Settings
Register Options Shortcuts (Regular Copy)
Register Options Shortcuts (Express Copy)
Send
Common Settings
Fax Settings
Store/Access Files
Common Settings
Copy Basic Features Screen
Color Balance (Options)
Setting Information
Case A
Case B
Case C
Set Destination
Rename Address List
Register One-Touch
Setting Information
Case A
Case B
Case C
Function Settings
Receive/Forward
Common Settings
Setting Information
Case A
Case B
Case C
Quick Menu Settings
Button File
Setting Information
Case A
Case B
Case C
Workflow Composer
Flow Data File
Operation Setting File
MEAP User Setting Information
Data
MEAP Application Setting Information
Data
Setting Information
Case A
Case B
Case C
Preferences
Paper Settings
Paper Type Management Settings
Setting Information
Case A
Case B
Case C
Web Access Settings*
Favorites
Settings
