[Cyan]
-8 to +8; 0*
[Magenta]
-8 to +8; 0*
[Yellow]
-8 to +8; 0*
[Black]
-8 to +8; 0*
[Cyan]
[High]
-8 to +8; 0*
[Medium]
-8 to +8; 0*
[Low]
-8 to +8; 0*
[Magenta]
[High]
-8 to +8; 0*
[Medium]
-8 to +8; 0*
[Low]
-8 to +8; 0*
[Yellow]
[High]
-8 to +8; 0*
[Medium]
-8 to +8; 0*
[Low]
-8 to +8; 0*
[Black]
[High]
-8 to +8; 0*
[Medium]
-8 to +8; 0*
[Low]
-8 to +8; 0*
If you set the Resolution to [600 dpi], the following restriction applies:
You can only select [High 1] or [High 2] for the Gradation mode.
If you set Resolution to [600 dpi] and Gradation to [Printer Default], the Gradation mode will automatically switch to [High 1] even if it is set to [Standard].
If you set the Resolution to [1200 dpi], the following restrictions apply:
You can only select [Standard] for the Gradation mode.
If you set Resolution to [1200 dpi] and Gradation to [Printer Default], the Gradation mode will automatically switch to [Standard] even if it is set to [High 1] or [High 2].
If you select [1200 dpi] for [Resolution], you cannot specify the following settings: rotate collate, different paper sizes (LTR/LGL), and double stapling on the short edge of A4 and LTR size paper.
[Mode 1]:
Smoothly prints the edges of characters, lines, and diagrams that have dark colors. Select [Mode 1] to perform printing normally.
[Mode 2]:
Smoothly prints not only the edges of diagrams, but also the halftones inside the diagrams. Set [Mode 2] if large characters and halftones inside fat lines that have dark colors are misaligned and not printed smoothly when printing with [Mode 1] set.
[Mode 3]:
Smoothly prints characters and lines that have dark colors on a halftone background. Set [Mode 3] if large characters and halftones inside fat lines that have dark colors are misaligned, or when the edges of characters and lines that have light colors are uneven, and not printed smoothly when printing with [Mode 1] set.
[Mode 4]:
Smoothly prints the edges of various objects. Set [Mode 4] if the edges of large characters and fat lines that have light colors are uneven and not printed smoothly when printing with [Mode 1] set.
[Mode 5]:
Evenly prints images and halftone objects. Set [Mode 5] if the gradation bands of images and diagrams are uneven or the dithering patterns are uneven when printing with [Mode 1] set.
[Mode 6]:
Evenly prints all objects. Set [Mode 6] if the halftones of the entire image are misaligned and uneven when printing with [Mode 1] set.
If [Resolution] is set to [1200 dpi], the [Mode 1] to [Mode 4] settings are disabled and the same processing as [Mode 5] is performed. If [Error Diffusion] is set in [Halftones], the [Mode 1] to [Mode 4] settings are disabled, and the same processing as [Mode 6] is performed.
The internal restriction value cannot be changed.
This setting can only be applied to jobs in the PS mode and PDF mode.
If [Gradation] is selected, characters and lines may bleed.
If [Text] is selected, the color may not match.
The Density mode is not available if you set [Toner Save] to [On].
The Toner Save mode is not available if you set [Resolution] to [1200 dpi].
Depending on the data to be printed, the Toner Save mode may not be applied even if you select [On].
If you select [On] for [Toner Save], very light or finely detailed images may not be printed clearly.
The Resolution mode cannot be applied to jobs in PCL5c mode.
When printing on large scale paper, set [Resolution] to [600 dpi]. If you select [1200 dpi], there will not be enough memory necessary to process printing and printing will not be possible.
The Toner Volume Adjustment mode can only be applied to jobs in the PS mode and PDF mode.
If you select [Gradation] for [Toner Volume Adjustment], characters and lines may bleed.
If you select [Text] for [Toner Volume Adjustment], the color may not match.
The Line Control mode can only be applied to jobs in the UFR II mode, PCL6 mode, PS mode, and PDF mode.
