If you are copying onto the back side of a previously printed sheet, load the paper as indicated below.
Paper drawer: Load the side to copy on face up.
Multi-purpose tray: Load the side to copy on face down.
Other Settings
Example of Stapling Position
Corner: Top Right
Double: Right ![]() LTR, EXEC
Corner: Top Right
Double: Top ![]() 11" x 17", LGL, LTRR
Corner: Top Right
![]() LTR, EXEC
Corner: Top Right
Double: Right ![]() 11" x 17", LGL, LTRR
Preprinted paper
Loading location: Paper drawer
Preprinted paper: Face up |
Loading location: Multi-purpose tray
Preprinted paper: Face down |
Original
Loading location: Platen glass
Original: Face down |
Stapling setting
Corner: Top Right
Double: Right |
Corner: Bottom Right
Double: Right |
Corner: Top Right
Corner: Top Right
Double: Right |
Loading location: Feeder
Original: Face up |
Stapling setting
Corner: Top Right
Double: Right |
Double: Right |
Corner: Top Right
Corner: Top Right
Double: Right |
Auto Rotation Setting
Both ON and OFF available
Both ON and OFF available (ON when
loaded vertically in the multi-purpose tray or vertically in a paper drawer) |
Other Settings
Corner: Top Left
Double: Left
![]() LTR, EXEC
Corner: Top Left
Corner: Top Left
![]() LTR, EXEC
Corner: Top Left
Double: Left ![]() 11" x 17", LGL, LTRR
Preprinted paper
Original
Stapling setting
Corner: Top Left
Double: Left |
Corner: Top Right
Double: Right |
Corner: Top Left
Corner: Top Left
Double: Left |
Original: Face up |
Stapling setting
Corner: Top Left
Double: Left |
Corner: Top Right
Double: Right |
Corner: Top Left
Corner: Top Left
Double: Left |
(ON when
Other Settings
Example Output
![]() LTR, EXEC
![]() LTR, LTRR, EXEC
Preprinted paper
Original
Original: Face down
Original: Face up
(ON when
Function
Functions that Cannot Be Used in Combination
Preset Zoom
Zoom by Percentage*1, XY Independent*1, Auto XY Ratio*1, Auto Zoom*1, Set by Length*1, Poster (Number of Output Pages)*1, Poster (%)*1, N on 1*1, Booklet Scanning*1, Divided Booklet*1, Creep Correction*1
Zoom by Percentage
Preset Zoom*1, XY Independent*1, Auto XY Ratio*1, Auto Zoom*1, Set by Length*1, Poster (Number of Output Pages)*1, Poster (%)*1, N on 1*1, Booklet Scanning*1, Divided Booklet*1, Creep Correction*1
XY Independent
Preset Zoom*1, Zoom by Percentage*1, Auto XY Ratio*1, Auto Zoom*1, Set by Length*1, Poster (Number of Output Pages)*1, Poster (%)*1, N on 1*1, Booklet Scanning*1, Divided Booklet*1, Creep Correction*1
Auto XY Ratio
Preset Zoom*1, Zoom by Percentage*1, XY Independent*1, Auto Zoom*1, Set by Length*1, Automatic Paper Selection, Poster (Number of Output Pages)*1, Poster (%)*1, N on 1*1, Repeat Images (Auto), Booklet Scanning*1, Between Batches, Divided Booklet*1, Creep Correction*1
Auto Zoom
Preset Zoom*1, Zoom by Percentage*1, XY Independent*1, Auto XY Ratio*1, Set by Length*1, Automatic Paper Selection, Poster (Number of Output Pages)*1, Poster (%)*1, Repeat Images (Auto), Between Batches
Set by Length
Preset Zoom*1, Zoom by Percentage*1, XY Independent*1, Auto XY Ratio*1, Auto Zoom*1, Poster (Number of Output Pages)*1, Poster (%)*1
Fit to Page
Poster (Number of Output Pages), Poster (%), N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Mirror Image, Repeat Images, Repeat Images (Auto), Booklet Scanning, Do Not Booklet Scan, Between Batches, Page Numbering, Copy Set Numbering, Watermark, Print Date, Divided Booklet, Creep Correction
Function
Manual Paper Selection*1, Custom Size*1, Poster (Number of Output Pages)*1, N on 1*1, Booklet Scanning*1, Do Not Booklet Scan*1, Between Batches, Auto XY Ratio*1, Auto Zoom*1, Rotate 90 Degrees: Collating*1, Rotate 90 Degrees: Group*1, Saddle Stitch*1, Saddle Fold*1, Divided Booklet*1, Creep Correction*1
Automatic Paper Selection*1, Custom Size*1, Between Batches
Custom Size
Automatic Paper Selection*1, Manual Paper Selection*1, 1-Sided
2-Sided, Book 2-Sided, 2-Sided 2-Sided, Poster (Number of Output Pages), Poster (%), Book 2 Pages, N on 1, Booklet Scanning, Do Not Booklet Scan, Between Batches, Divided Booklet, Creep Correction |
Scanning Originals Loaded in the Feeder
Book
2-Sided, Poster (Number of Output Pages), Poster (%), Book 2 Pages |
Function
Collate
Poster (Number of Output Pages)*1, Poster (%)*1, Transparency Cover Sheets*1, Booklet Scanning*1, Do Not Booklet Scan, Between Batches, Group*1, Rotate 90 Degrees: Collating*1, Rotate 90 Degrees: Group*1, Offset Collate*1, Offset Group*1, Staple*1, Saddle Stitch*1, Divided Booklet*1, Creep Correction*1
Group
Poster (Number of Output Pages), Poster (%), Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Collate*1, Rotate 90 Degrees: Collating*1, Rotate 90 Degrees: Group*1, Offset Collate*1, Offset Group*1, Staple*1, Saddle Stitch*1, Saddle Fold, Copy Sample, Copy Set Numbering, Divided Booklet, Creep Correction, Secure Watermark*2
Automatic Paper Selection, Poster (Number of Output Pages), Poster (%), Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Collate*1, Group*1, Rotate 90 Degrees: Group*1, Offset Collate*1, Offset Group*1, Staple*1, Saddle Stitch*1, Saddle Fold, Divided Booklet, Creep Correction
Automatic Paper Selection, Poster (Number of Output Pages), Poster (%), Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Collate*1, Group*1, Rotate 90 Degrees: Collating*1, Offset Collate*1, Offset Group*1, Staple*1, Saddle Stitch*1, Saddle Fold, Copy Sample, Copy Set Numbering, Divided Booklet, Creep Correction, Secure Watermark*2
Offset Collate
Poster (Number of Output Pages)*1, Poster (%)*1, Transparency Cover Sheets*1, Booklet Scanning*1, Do Not Booklet Scan, Between Batches, Collate*1, Group*1, Rotate 90 Degrees: Collating*1, Rotate 90 Degrees: Group*1, Offset Group*1, Staple*1, Saddle Stitch*1, Saddle Fold, Divided Booklet*1, Creep Correction*1
Offset Group
Poster (Number of Output Pages), Poster (%), Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Collate*1, Group*1, Rotate 90 Degrees: Collating*1, Rotate 90 Degrees: Group*1, Offset Collate*1, Staple*1, Saddle Stitch*1, Saddle Fold, Copy Sample, Copy Set Numbering, Divided Booklet, Creep Correction, Secure Watermark*2
Staple
Poster (Number of Output Pages), Poster (%), Mirror Image, Transparency Cover Sheets, Booklet Scanning, Do Not Booklet Scan, Between Batches, Collate*1, Group*1, Rotate 90 Degrees: Collating*1, Rotate 90 Degrees: Group*1, Offset Collate, Offset Group, Saddle Stitch*1, Saddle Fold, Divided Booklet, Creep Correction
Saddle Stitch
Automatic Paper Selection, Book
2-Sided, 2-Sided 1-Sided, Poster (Number of Output Pages), Poster (%), Book 2 Pages, N on 1, Mirror Image, Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Collate*1, Group*1, Rotate 90 Degrees: Collating*1, Rotate 90 Degrees: Group*1, Offset Collate, Offset Group, Staple*1, Saddle Fold, Page Numbering, Copy Set Numbering, Watermark, Print Date, Divided Booklet, Creep Correction |
Function
Saddle Fold
2-Sided, 2-Sided 1-Sided, Poster (Number of Output Pages), Poster (%), Book 2 Pages, N on 1, Mirror Image, Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple, Saddle Stitch, Page Numbering, Copy Set Numbering, Watermark, Print Date, Divided Booklet, Creep Correction |
Function
1-Sided
2-Sided |
Custom Size, Book
2-Sided*1, 2-Sided 2-Sided*1, 2-Sided 1-Sided*1, Poster (Number of Output Pages), Poster (%), Book 2 Pages, Transparency Cover Sheets, Booklet Scanning, Do Not Booklet Scan, Divided Booklet, Creep Correction |
Book
2-Sided |
Custom Size, 1-Sided
2-Sided*1, 2-Sided 2-Sided*1, 2-Sided 1-Sided*1, Poster (Number of Output Pages), Poster (%), Book 2 Pages, N on 1, Erase Binding, Repeat Images, Repeat Images (Auto), Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Scanning Originals Loaded in the Feeder, Between Batches, Saddle Stitch, Saddle Fold, Different Size Originals, Divided Booklet, Creep Correction, Print & Check |
2-Sided
2-Sided |
2-Sided*1, Book 2-Sided*1, 2-Sided 1-Sided*1, Poster (Number of Output Pages), Poster (%), Book 2 Pages, Transparency Cover Sheets, Booklet Scanning, Do Not Booklet Scan, Divided Booklet, Creep Correction |
2-Sided
1-Sided |
1-Sided
2-Sided*1, Book 2-Sided*1, 2-Sided 2-Sided*1, Poster (Number of Output Pages), Poster (%), Book 2 Pages, Transparency Cover Sheets, Booklet Scanning, Do Not Booklet Scan, Saddle Stitch, Saddle Fold, Divided Booklet, Creep Correction |
Auto (Color/Black), Background Density (Auto), Preset Zoom*1, Zoom by Percentage*1, XY Independent*1, Auto XY Ratio*1, Auto Zoom*1, Set by Length*1, Fit to Page, Automatic Paper Selection, Custom Size, 1-Sided
2-Sided, Book 2-Sided, 2-Sided 2-Sided, 2-Sided 1-Sided, Poster (%)*1, Book 2 Pages, N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Position), Shift (By Numeric Keys), Gutter, Mirror Image, Repeat Images, Repeat Images (Auto), Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Scanning Originals Loaded in the Feeder, Job Build, Between Batches, Collate, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple, Saddle Stitch, Saddle Fold, Different Size Originals, Copy Sample, Divided Booklet, Creep Correction, Print & Check |
Poster (%)
Auto (Color/Black), Background Density (Auto), Preset Zoom*1, Zoom by Percentage*1, XY Independent*1, Auto XY Ratio*1, Auto Zoom*1, Set by Length*1, Fit to Page, Custom Size, 1-Sided
2-Sided, Book 2-Sided, 2-Sided 2-Sided, 2-Sided 1-Sided, Poster (Number of Output Pages)*1, Book 2 Pages, N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Position), Shift (By Numeric Keys), Gutter, Mirror Image, Repeat Images, Repeat Images (Auto), Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Scanning Originals Loaded in the Feeder, Job Build, Between Batches, Collate, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple, Saddle Stitch, Saddle Fold, Different Size Originals, Copy Sample, Divided Booklet, Creep Correction, Print & Check |
Book
2 Pages |
2-Sided, Book 2-Sided, 2-Sided 2-Sided, 2-Sided 1-Sided, Poster (Number of Output Pages), Poster (%), N on 1, Erase Binding, Repeat Images, Repeat Images (Auto), Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Scanning Originals Loaded in the Feeder, Between Batches, Saddle Stitch, Saddle Fold, Different Size Originals, Divided Booklet, Creep Correction, Print & Check |
N on 1
Fit to Page, Automatic Paper Selection, Custom Size, Book
2-Sided, Poster (Number of Output Pages), Poster (%), Book 2 Pages, Erase Original Frame, Erase Book Frame, Shift (By Numeric Keys), Mirror Image, Repeat Images, Repeat Images (Auto), Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Saddle Stitch, Saddle Fold, Different Size Originals, Divided Booklet, Creep Correction, Print & Check |
Fit to Page, Poster (Number of Output Pages), Poster (%), N on 1, Erase Book Frame*1, Erase Binding*1, Mirror Image, Repeat Images, Repeat Images (Auto), Booklet Scanning, Do Not Booklet Scan, Between Batches, Page Numbering, Copy Set Numbering, Watermark, Print Date, Divided Booklet, Creep Correction
Erase Book Frame
Fit to Page, Poster (Number of Output Pages), Poster (%), N on 1, Erase Original Frame*1, Erase Binding*1, Mirror Image, Repeat Images, Repeat Images (Auto), Booklet Scanning, Do Not Booklet Scan, Between Batches, Page Numbering, Copy Set Numbering, Watermark, Print Date, Divided Booklet, Creep Correction
Erase Binding
Fit to Page, Book
2-Sided, Poster (Number of Output Pages), Poster (%), Book 2 Pages, Erase Original Frame*1, Erase Book Frame*1, Mirror Image, Repeat Images, Repeat Images (Auto), Booklet Scanning, Do Not Booklet Scan, Between Batches, Page Numbering, Copy Set Numbering, Watermark, Print Date, Divided Booklet, Creep Correction |
Interrupt
Between Batches
Function
Shift (By Position)
Poster (Number of Output Pages), Poster (%), Shift (By Numeric Keys)*1, Mirror Image, Repeat Images, Repeat Images (Auto), Between Batches
Poster (Number of Output Pages), Poster (%), N on 1, Shift (By Position)*1, Mirror Image, Repeat Images, Repeat Images (Auto), Booklet Scanning, Do Not Booklet Scan, Between Batches, Page Numbering, Copy Set Numbering, Watermark, Print Date, Divided Booklet, Creep Correction
Gutter
Poster (Number of Output Pages), Poster (%), Mirror Image, Repeat Images, Repeat Images (Auto), Booklet Scanning, Do Not Booklet Scan, Between Batches, Divided Booklet, Creep Correction, Scan Lock Information (TL Code)
1-Sided
2-Sided, Book 2-Sided, 2-Sided 2-Sided, 2-Sided 1-Sided, Poster (Number of Output Pages), Poster (%), Book 2 Pages, N on 1, Mirror Image, Repeat Images, Repeat Images (Auto), Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Collate, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple, Saddle Stitch, Saddle Fold, Page Numbering, Copy Set Numbering, Watermark, Print Date, Divided Booklet, Creep Correction, Print & Check |
Front Cover
Book
2-Sided, Poster (Number of Output Pages), Poster (%), Book 2 Pages, N on 1, Mirror Image, Repeat Images, Repeat Images (Auto), Transparency Cover Sheets, Booklet Scanning, Do Not Booklet Scan, Between Batches, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Group, Saddle Stitch, Saddle Fold, Page Numbering*3, Copy Set Numbering*3, Watermark*3, Print Date*3, Divided Booklet, Creep Correction |
Book
Function
Booklet Scanning
2-Sided, Book 2-Sided, 2-Sided 2-Sided, 2-Sided 1-Sided, Poster (Number of Output Pages), Poster (%), Book 2 Pages, N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Numeric Keys), Gutter, Mirror Image, Repeat Images, Repeat Images (Auto), Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Do Not Booklet Scan, Between Batches, Collate, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple, Saddle Stitch, Saddle Fold, Different Size Originals, Watermark, Print Date, Divided Booklet*1, Print & Check, Secure Watermark, Scan Lock Information (TL Code), Tracking Information |
Do Not Booklet Scan
2-Sided, Book 2-Sided, 2-Sided 2-Sided, 2-Sided 1-Sided, Poster (Number of Output Pages), Poster (%), Book 2 Pages, N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Numeric Keys), Gutter, Mirror Image, Repeat Images, Repeat Images (Auto), Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Between Batches, Collate, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple, Saddle Stitch, Saddle Fold, Different Size Originals, Page Numbering, Copy Set Numbering, Watermark, Print Date, Divided Booklet, Creep Correction, Print & Check, Secure Watermark, Scan Lock Information (TL Code), Tracking Information |
Divided Booklet
2-Sided, Book 2-Sided, 2-Sided 2-Sided, 2-Sided 1-Sided, Poster (Number of Output Pages), Poster (%), Book 2 Pages, N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Numeric Keys), Gutter, Mirror Image, Repeat Images, Repeat Images (Auto), Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning*1, Do Not Booklet Scan, Between Batches, Collate, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple, Saddle Stitch, Saddle Fold, Different Size Originals, Watermark, Print Date, Print & Check, Secure Watermark, Scan Lock Information (TL Code), Tracking Information |
Creep Correction
2-Sided, Book 2-Sided, 2-Sided 2-Sided, 2-Sided 1-Sided, Poster (Number of Output Pages), Poster (%), Book 2 Pages, N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Numeric Keys), Gutter, Mirror Image, Repeat Images, Repeat Images (Auto), Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Do Not Booklet Scan, Between Batches, Collate, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple, Saddle Stitch, Saddle Fold, Different Size Originals, Watermark, Print Date, Print & Check, Secure Watermark, Scan Lock Information (TL Code), Tracking Information |
Function
Sharpness
Between Batches, Secure Watermark, Scan Lock Information (TL Code), Tracking Information
Nega/Posi
Mirror Image
Fit to Page, Poster (Number of Output Pages), Poster (%), N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Position), Shift (By Numeric Keys), Gutter, Repeat Images, Repeat Images (Auto), Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Staple, Saddle Stitch, Saddle Fold, Page Numbering, Copy Set Numbering, Watermark, Print Date, Divided Booklet, Creep Correction, Secure Watermark, Scan Lock Information (TL Code), Tracking Information
Repeat Images
Fit to Page, Book
2-Sided, Poster (Number of Output Pages), Poster (%), Book 2 Pages, N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Position), Shift (By Numeric Keys), Gutter, Mirror Image, Repeat Images (Auto)*1, Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Different Size Originals, Page Numbering, Copy Set Numbering, Watermark, Print Date, Divided Booklet, Creep Correction, Print & Check, Secure Watermark, Scan Lock Information (TL Code), Tracking Information |
Auto XY Ratio, Auto Zoom, Fit to Page, Book
2-Sided, Poster (Number of Output Pages), Poster (%), Book 2 Pages, N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Position), Shift (By Numeric Keys), Gutter, Mirror Image, Repeat Images*1, Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Between Batches, Different Size Originals, Page Numbering, Copy Set Numbering, Watermark, Print Date, Divided Booklet, Creep Correction, Print & Check, Secure Watermark, Scan Lock Information (TL Code), Tracking Information |
Job Build
Poster (Number of Output Pages), Poster (%), Between Batches
Between Batches
Background Density (Adjust All Color), Auto XY Ratio, Auto Zoom, Fit to Page, Automatic Paper Selection, Manual Paper Selection, Custom Size, Book
2-Sided, Sharpness, Adjust One-Touch Color (Vivid Colors/Tranquil Colors), Adjust One-Touch Color (Lighten Image/Darken Image/Highlight Reproduction), Adjust One-Touch Color (Sepia Tone), Color Balance, Color Balance (Fine Adjust Density), Poster (Number of Output Pages), Poster (%), Book 2 Pages, N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Position), Shift (By Numeric Keys), Gutter, Nega/Posi, Mirror Image, Repeat Images, Repeat Images (Auto), Transparency Cover Sheets, Front Cover, Sheets/Chapter Pages, Booklet Scanning, Do Not Booklet Scan, Job Build, Collate, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple, Saddle Stitch, Saddle Fold, Different Size Originals, Copy Sample, Interrupt, Page Numbering, Copy Set Numbering, Watermark, Print Date, Divided Booklet, Creep Correction, Print & Check, Secure Watermark, Scan Lock Information (TL Code), Tracking Information |
Book
2-Sided, Poster (Number of Output Pages), Poster (%), Book 2 Pages, N on 1, Repeat Images, Repeat Images (Auto), Booklet Scanning, Do Not Booklet Scan, Between Batches, Divided Booklet, Creep Correction |
Copy Sample
Poster (Number of Output Pages), Poster (%), Between Batches, Group*1, Rotate 90 Degrees: Group*1, Offset Group*1
Function
Page Numbering
Fit to Page, Adjust One-Touch Color (Sepia Tone), Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Numeric Keys), Mirror Image, Repeat Images, Repeat Images (Auto), Transparency Cover Sheets, Front Cover*3, Sheets/Chapter Pages*3, Do Not Booklet Scan, Between Batches, Saddle Stitch, Saddle Fold, Copy Set Numbering*5, Watermark*5, Print Date*5, Two Colors
Copy Set Numbering
Fit to Page, Adjust One-Touch Color (Sepia Tone), Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Numeric Keys), Mirror Image, Repeat Images, Repeat Images (Auto), Transparency Cover Sheets, Front Cover*3, Sheets/Chapter Pages*3, Do Not Booklet Scan, Between Batches, Group, Rotate 90 Degrees: Group, Offset Group, Saddle Stitch, Saddle Fold, Page Numbering*5, Watermark*5, Print Date*5, Two Colors, Secure Watermark, Scan Lock Information (TL Code), Tracking Information
Watermark
Fit to Page, Adjust One-Touch Color (Sepia Tone), Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Numeric Keys), Mirror Image, Repeat Images, Repeat Images (Auto), Transparency Cover Sheets, Front Cover*3, Sheets/Chapter Pages*3, Booklet Scanning, Do Not Booklet Scan, Between Batches, Saddle Stitch, Saddle Fold, Page Numbering*5, Copy Set Numbering*5, Print Date*5, Two Colors, Divided Booklet, Creep Correction, Secure Watermark, Scan Lock Information (TL Code), Tracking Information
Print Date
Fit to Page, Adjust One-Touch Color (Sepia Tone), Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Numeric Keys), Mirror Image, Repeat Images, Repeat Images (Auto), Transparency Cover Sheets, Front Cover*3, Sheets/Chapter Pages*3, Booklet Scanning, Do Not Booklet Scan, Between Batches, Saddle Stitch, Saddle Fold, Page Numbering*5, Copy Set Numbering*5, Watermark*5, Two Colors, Divided Booklet, Creep Correction, Secure Watermark, Scan Lock Information (TL Code), Tracking Information
Print & Check
Book
2-Sided, 2-Sided 2-Sided, 2-Sided 1-Sided, Poster (Number of Output Pages), Poster (%), Book 2 Pages, N on 1, Repeat Images, Repeat Images (Auto), Transparency Cover Sheets, Booklet Scanning, Do Not Booklet Scan, Between Batches, Divided Booklet, Creep Correction |
Secure Watermark
Sharpness, Adjust One-Touch Color (Vivid Colors/Tranquil Colors), Adjust One-Touch Color (Lighten Image/Darken Image/Highlight Reproduction), Adjust One-Touch Color (Sepia Tone), Color Balance, Color Balance (Fine Adjust Density), Single Color, Nega/Posi, Mirror Image, Repeat Images, Repeat Images (Auto), Booklet Scanning, Do Not Booklet Scan, Between Batches, Group*2, Rotate 90 Degrees: Group*2, Offset Group*2, Copy Set Numbering, Watermark, Print Date, Two Colors, Divided Booklet, Creep Correction, Scan Lock Information (TL Code), Tracking Information
Sharpness, Adjust One-Touch Color (Vivid Colors/Tranquil Colors), Adjust One-Touch Color (Lighten Image/Darken Image/Highlight Reproduction), Adjust One-Touch Color (Sepia Tone), Color Balance, Color Balance (Fine Adjust Density), Single Color, Nega/Posi, Mirror Image, Repeat Images, Repeat Images (Auto), Booklet Scanning, Do Not Booklet Scan, Between Batches, Copy Set Numbering, Watermark, Print Date, Two Colors, Divided Booklet, Creep Correction, Secure Watermark, Tracking Information
Sharpness, Adjust One-Touch Color (Vivid Colors/Tranquil Colors), Adjust One-Touch Color (Lighten Image/Darken Image/Highlight Reproduction), Adjust One-Touch Color (Sepia Tone), Color Balance, Color Balance (Fine Adjust Density), Single Color, Nega/Posi, Mirror Image, Repeat Images, Repeat Images (Auto), Booklet Scanning, Do Not Booklet Scan, Between Batches, Copy Set Numbering, Watermark, Print Date, Two Colors, Divided Booklet, Creep Correction, Secure Watermark, Scan Lock Information (TL Code)
Function
Auto (Color/Black)
Full Color*1, Black*1, Adjust One-Touch Color (Sepia Tone)*1, Single Color*1, Two Colors*1, Poster (Number of Output Pages)*1, Poster (%)*1
Full Color
Auto (Color/Black)*1, Black*1, Adjust One-Touch Color (Sepia Tone)*1, Single Color*1, Two Colors*1
Black
Auto (Color/Black)*1, Full Color*1, Adjust One-Touch Color (Sepia Tone)*1, Single Color*1, Two Colors*1
Background Density (Adjust Each Color)*1, Background Density (Adjust All Color)*1, Poster (Number of Output Pages), Poster (%)
Background Density (Auto), Background Density (Adjust All Color)
Background Density (Auto), Background Density (Adjust Each Color), Between Batches
Color Balance*1, Color Balance (Fine Adjust Density)*1, Between Batches, Secure Watermark, Scan Lock Information (TL Code), Tracking Information
Auto (Color/Black)*1, Full Color*1, Black*1, Single Color, Between Batches, Page Numbering, Copy Set Numbering, Watermark, Print Date, Two Colors, Secure Watermark, Scan Lock Information (TL Code), Tracking Information
Color Balance
Adjust One-Touch Color (Lighten Image/Darken Image/Highlight Reproduction)*1, Between Batches, Secure Watermark, Scan Lock Information (TL Code), Tracking Information
Single Color
Auto (Color/Black)*1, Full Color*1, Black*1, Adjust One-Touch Color (Sepia Tone), Two Colors*1, Secure Watermark, Scan Lock Information (TL Code), Tracking Information
Two Colors
Auto (Color/Black)*1, Full Color*1, Black*1, Adjust One-Touch Color (Sepia Tone), Single Color*1, Page Numbering, Copy Set Numbering, Watermark, Print Date, Secure Watermark, Scan Lock Information (TL Code), Tracking Information
