Routine Cleaning
If the original is not copied clearly, clean the following parts of the machine. For high-quality printouts, we recommend cleaning these parts once or twice a month.
Platen glass
Underside of the feeder/platen cover
Feeder's rollers
WARNING
When cleaning the machine, first turn OFF the main power switch, and disconnect the power cord. Failure to observe these steps may result in a fire or electrical shock.
Disconnect the power cord from the power outlet regularly, and clean the area around the base of the power plug's metal pins and the power outlet with a dry cloth to ensure that all dust and grime is removed. If the power cord is connected for a long period of time in a damp, dusty, or smoky location, dust can build up around the power plug and become damp. This may cause a short circuit and result in a fire.
When cleaning with a cloth, do not dampen it too much, as this may damage the original or break the machine.
Do not use alcohol, benzene, paint thinner, or other solvents for cleaning. Doing so may result in damage to the plastic parts.
The feeder is standard-equipped for the imageRUNNER ADVANCE 4251/4245.
» Maintenance » Routine Cleaning
0CYL-0H3
