Cleaning the Platen Glass and Underside of the Feeder/Platen Cover
If the platen glass or the underside of the feeder/platen cover is dirty, the original may not be scanned clearly, or the size of the original may be detected incorrectly. Clean the platen glass and the underside of the feeder by following the procedure below.
Clean the platen glass and the underside of the feeder/platen cover with a cloth which is wrung after being dampened in water, and then wipe them clean with a soft, dry cloth.
1. Clean the platen glass.
2. Clean the underside of the feeder/platen cover.
If stains won't come out, clean the platen glass and the underside of the feeder/platen cover with a cloth which is wrung after being dampened in detergent, and then wipe them clean with a soft, dry cloth.
» Maintenance » Routine Cleaning » Cleaning the Platen Glass and Underside of the Feeder/Platen Cover
0CYL-0H4
