Available Administrator Settings Table (Remote UI)
If the administrator is specified, you can restrict operations by general users and allow the administrator to set the settings of each function from (Settings/Registration). The settings available for operation vary according to the type of administrator. This section describes the settings in (Settings/Registration) that each administrator can operate.
For information on the types of administrators, see "Administrator Settings."
All users can set the settings in [Adjustment/Maintenance] (Settings/Registration).
Preferences
If the administrator is specified, the settings below in Preferences can be set only by the administrator.
: Only the administrator can change the settings.
-: Depending on the type of the administrator when using the SSO-H, settings cannot be changed.
System Manager/System Administrator (Administrator)
Network Administrator (NetworkAdmin)
Device Administrator (DeviceAdmin)
[Restart Device]
[Paper Settings]
Paper Type Management Settings
[Timer/Energy Settings]
Date/Time Settings
Time Format
Quick Startup Settings for Main Power
Restrict Auto Reset Time
[Network Settings]
TCP/IP Settings
IP Address Settings (IPv4)
IP Address Settings (IPv6)
DNS Settings (IPv4)
DNS Settings (IPv6)
WINS Settings
LPD Print Settings
RAW Print Settings
SNTP Settings
FTP Print Settings
WSD Settings
FTP PASV Mode Settings
IPP Print Settings
Multicast Discovery Settings
HTTP Settings
WebDAV Server Settings
SSL Settings
Proxy Settings
Department ID PIN Confirmation Settings
IPSec Settings
NetWare Settings
AppleTalk Settings
SMB Server Settings
SNMP Settings
Dedicated Port Settings
Spooler
Waiting Time for Connection at Startup
Ethernet Driver Settings
IEEE 802.1X Settings
Firewall Settings
IPv4 Address Filter
IPv6 Address Filter
MAC Address Filter
IP Address Block Log
[External Interface]
USB Settings
Function Settings
If the administrator is specified, the settings below in Function Settings can be set only by the administrator.
[Common Settings]
Print Settings
Copy Set Numbering Option Settings
Secure Watermark/Document Scan Lock Settings*
Generate File
Rights Management Server Settings
Document Scan Lock Operational Settings
Set Authentication Method
[Printer]
Restrict Printer Jobs
PDL Selection (Plug-n-Play)
[Send]
Common Settings
Confirm SSL Certificate for WebDAV TX
TX Report/Communication Management Report
TX Report - Attach TX Image to Report
Network Settings - E-Mail/I-Fax Settings
Confirm SSL Certificate for SMTP TX
Confirm SSL Certificate for POP RX
Communications Settings - E-Mail/I-Fax Settings
Limit New Destination
Only Send E-Mail to Myself
Only Send File to Personal Folder
Personal Folder Specification Method
TX Settings - Fax Settings
Fax TX Report/Fax Activity Report
Fax TX Report - Attach TX Image to Report
Set Line
PIN Code Access
Communications Settings-Fax Settings
Confirm Entered Fax Number
Allow Fax Driver TX
Remote Fax TX Settings
Remote Fax Settings
[Receive/Forward]
Common Settings
Divided Data RX Timeout/Always Send Notice for RX Errors
Handle Files with Forwarding Errors
Forwarding Settings
Memory Lock Settings
Fax Settings-RX Settings
RX Start Speed/RX Password
[Store/Access Files]
Settings for All Mail Boxes
Box Security Settings
Advanced Box Settings
Set Details
URI TX Settings
Delete Personal Space
Delete Shared Space
Save Operation Log
Network Settings
Protocol for External Reference
SSL Certificate Confirmation Settings for Network Access
Memory Media Settings
[Secure Print]
* The setting names may differ depending on the optional products available for use.
Destination Settings
If the administrator is specified, the settings below in Set Destination can be set only by the administrator.
[Address Book PIN]
[Manage Address Book Access Numbers]
[Address Book Export Settings]
[Register LDAP Server]
[Register/Edit LDAP Search]
[Acquire Remote Address Book]
[Make Remote Address Book Open]
Management Settings
If the administrator is specified, the settings below in Management Settings can be set only by the administrator.
[User Management]
System Manager/Contact Person Information Settings
Department ID Management
[Device Management]
Device Information Settings
Certificate Settings
Key and Certificate Settings
CA Certificate Settings
Certificate Revocation List (CRL) Settings
Display Job Status Before Authentication
Display Log
Audit Log Retrieval
Export/Clear Audit Log
Encryption Method Settings
[License/Other]
Message Board/Support Link
Remote UI Settings
Remote Operation Settings
MEAP Settings
Register/Update Software
[Data Management]
Hard Disk Data Complete Deletion
Import/Export All
Import
Export
Import/Export Results
Import/Export Individually
Address Lists
Device Settings (Forwarding Settings, Address Book, Send Function Favorite Settings)
Web Access Favorites
Printer Settings
Paper Information
Back Up/Restore Settings
Backup Location Settings
Auto Backup Settings
Back Up
Restore
Back Up/Restore Log
» Remote UI » Available Administrator Settings Table (Remote UI)
0CYL-1W1
