Category Top
Printing Functions
[Basic Settings] Tab
[Page Setup] Tab
[Finishing] Tab
[Paper Source] Tab
[Quality] Tab
Common Functions
[Device Settings] Tab
System Requirements
Installation
Setting the Printer Options
Other Software Programs
Printing Fundamentals
Printing
Viewing the Online Help
Scaling Documents
1-sided and 2-sided Printing
Booklet Printing
Poster Printing
Watermark Printing
Printing Functions
Common Functions
[Layout] Preferences Pane
[Finishing] Preferences Pane
[Quality] Preferences Pane
System Requirements
Installation
Printing
Scaling Documents
Setting Custom Paper Sizes
Booklet Printing
Using [Presets] for Printing
Personality
Menu Functions
Accessing the Settings Menu
Canceling Print Jobs
Report Settings
Copies
2-Sided Printing
Paper Feed
Paper Output
Print Quality
Layout
Auto Error Skip
Secure Print Delete Time
Timeout
Print After Completing RIP
Booklet
Saddle Stitch
Creep Correction
Transparency Interleaving
Copy Set Numbering
Personality
Mode Priority
Initialize
UFR II Settings
Halftones
Paper Save
PCL Settings
Paper Save
Orientation
Font Number
Point Size
Pitch
Form Lines
Character Code
Custom Paper
Unit of Measure
X Dimension
Y Dimension
Append CR to LF
Enlarge A4 Print Width
Halftones
PS Settings
Job Timeout
Print PS Errors
Halftones
Grayscale Conversion
Dot Gain Adjustment
Imaging Settings
Image Orientation
Zoom Mode
Print Position
Show Warnings
Enlarge Print Area
Halftones
PDF Settings
Enlarge/Reduce to Fit Size
Enlarge Print Area
N on 1
Comment Print
Halftones
Dot Gain Adjustment
XPS Settings
Halftones
Utility Settings
Restricting Printer Jobs
PDL Selection (Plug-n-play)
Printing Problems
Some Basic Facts about Fonts
What Is a Font?
Attributes of Fonts
Fonts and Scalable Fonts
Typeface Samples
Symbol Sets 1
Symbol Sets 2
Symbol Sets 3
Symbol Sets 4
Symbol Sets 5
Configuration Page
Release Notes
Bar Code Printing
Introduction
Menus and Their Functions
Building/Printing a Bar Code
Control Codes
Font Parameters
Bar Code Format Parameters
Bar Code Usages and Formats
Troubleshooting
List of Error Messages
Printing Problems
Top » Print » Setting the Machine (PS/PCL/UFR II Printer) » Settings Menu (Common Settings) » Paper Output
Paper Output
0CYL-1C0
Finishing
[Off], [Collate], [Group]*, [Rotate+Collate], [Rotate+Group], [Offset+Collate], [Copies], [Offset+Group], [Staple+Collate], [Staple+Group]
Copies to Offset (Offset+Collate):
1 to 9999; 1*
Staple Position (Staple+Collate):
Corner (Upper-L), Double (Top), Corner (Upper-R), Double (Right), Corner (Lower-R), Double (Bottom), Corner (Lower-L), and Double (Left)
Staple Position (Staple+Group):
Grp Upp L-Corner, Grp Double (Top), Grp Upp R-Corner, Grp Double (R), Grp Lwr R-Corner, Grp Double (Btm), Grp Lwr L-Corner, and Grp Double (L)
Some of the above options require specific delivery trays and may not be available unless appropriate delivery trays are attached.
: Available - : Unavailable
Inner Finisher-D1
Inner 2Way Tray-H1
Staple Finisher-G1, Booklet Finisher-G1
Collate
Group
Rotate+Collate
Rotate+Group
Offset+Collate
Offset+Group
Staple+Collate
Staple+Group
[Off]
This setting prints all copies of the same page before printing the next page.
[Collate]
This setting prints all pages of each copy before printing the next copy.
[Group]
[Rotate+Collate]
This setting prints all pages of each copy (collating), and rotates every other complete copy 90 degrees to indicate where each copy starts.
[Rotate+Group]
This setting prints all copies of the same page before printing the next page. It rotates every other complete set of pages to indicate where each new set starts.
[Offset+Collate]
This setting prints all pages of each copy (collating). It offsets every other complete copy by the number specified with this setting to indicate where each copy starts.
[Offset+Group]
This setting prints all copies of the same page before printing the next page. It offsets every other complete set of pages to indicate where each new set starts.
[Staple+Collate]
This setting prints all copies of the same page before printing the next page, and prepares them for stapling according to the option selected for [Staple+Group].
[Staple+Group]
Examples of each Finishing option when printing three copies of a three page document:
Off
Collate
Group
Rotate+Collate
Rotate+Group
Offset+Collate
Offset+Group
Staple+Collate
Staple+Group
A large print job may be automatically canceled by the machine. The maximum number of pages that can be printed at one time is approximately 20,000 pages. However, this number may be fewer than 20,000 if other functions (such as registering a form) are in use, or other jobs are being processed.
[Rotate+Collate] and [Rotate+Group] are available if the paper size is LTR, LTRR, A4, A4R, B5, or B5R.
If [Rotate+Collate] or [Rotate+Group] is selected, part of the print image may be cut off when the image is rotated. You need to load the same size paper as the original in the paper drawers in both landscape and portrait positions. If you do not, all the sheets will be printed in the orientation that the loaded paper is in.
[Offset+Collate] and [Offset+Group] are available if the following paper size is selected.
- When the Staple Finisher-G1 or the Booklet Finisher-G1 is attached:
A3, B4, A4, A4R, B5, 11"x17", LGL, LTR, LTRR
When you select [Staple+Collate] or [Staple+Group], you can select the stapling position.
When you are stapling paper in landscape orientation, the image orientation and the staple position may not match.
Inner Finisher-D1/Staple Finisher-G1/Booklet Finisher-G1
Corner (Upper-Left)
Double (Top)
Corner (Upper-Right)
Double (Right)
Corner (Lower-Right)
Double (Bottom)
Corner (Lower-Left)
Double (Left)
11" x 17"
LGL
LTR
LTRR
EXEC
A3
B4
A4
A4R
B5
* Will be stapled parallel to the edge of the paper.
The maximum number of sheets of thin or plain type paper that can be stapled at one time is:
A3, B4, A4R, 11" × 17", LGL, LTRR: 30 sheets
A4, B5, LTR, EXEC: 50 sheets
Make sure to select compatible settings when using Staple and Punch simultaneously. If conflicting settings are selected, such as the staple setting for the right side of the paper and the punch setting for the left, the printer will use neither Staple nor Punch.
Punch
[Off]*, [Top], [Bottom], [Left], [Right]
This setting enables you to specify the desired paper position for holes to be punched for binding.
This function is available for selection if the External 2/3 Hole Puncher-B2 is attached to the Staple Finisher-G1 or Booklet Finisher-G1.
The machine automatically selects how many holes to punch, depending on the selected paper size:
Two holes: LGL, LTRR
Three holes: 11" x 17", LTR, A3, A4
Make sure to select compatible settings when using Staple and Punch simultaneously. If conflicting settings are selected, such as the staple setting for the right side of the paper and the punch setting for the left, the machine will use neither Staple nor Punch.
Holes can only be punched in Thin, Plain, Recycled, Color, Heavy, and Bond.
