Printer Driver Setting
Paper
Letter
A4
A4
Letter
11" x 17"
A3
A3
11" x 17"
If you are printing from an OS that lacks a printer driver for the machine (MS-DOS, UNIX, etc.), make sure that the paper loaded in the paper drawer matches the paper size specified in this setting. If the paper size specified in this setting is not available, an error message is displayed when the machine tries to print the job and the machine stops. In addition, if a paper source has not been selected through the application, the machine automatically selects the default print settings for the paper size and type. (See "Enabling Paper Drawer Auto Selection.")
Use the following figures as a guideline to decide whether paper should be specified as Plain Paper or Heavy Paper.
Plain Paper: 16 lb bond to 24 lb bond (60 g/m2 to 90 g/m2)
Heavy Paper: 25 lb bond to 80 lb cover (91 g/m2 to 220 g/m2) Canon transparency film is recommended for printing on transparencies.
Canon label paper is recommended for printing on labels.
Only Plain Paper, Color Paper, Recycled Paper, Heavy Paper (25 lb bond to 28 lb bond (91 g/m2 to 105 g/m2)), and Pre-punched Paper can be printed using two-sided printing.
