Top » How to Use This Manual » How to Use This Manual (e-Manual)
0CYL-26S
Symbols Used in This Manual
The following symbols are used in this manual to explain procedures, restrictions, handling precautions, and instructions that should be observed for safety.
WARNING
Indicates a warning concerning operations that may lead to death or injury to persons if not performed correctly. To use the machine safely, always pay attention to these warnings.
CAUTION
Indicates a caution concerning operations that may lead to injury to persons if not performed correctly. To use the machine safely, always pay attention to these cautions.
Indicates operational requirements and restrictions. Be sure to read these items carefully to operate the machine correctly, and avoid damage to the machine or property.
Indicates a clarification of an operation, or contains additional explanations for a procedure. Reading these notes is highly recommended.
Indicates an operation that must not be performed. Read these items carefully, and make sure not to perform the described operations.
Keys and Buttons Used in This Manual
The following key and button names are a few examples of how keys to press and buttons to click are expressed in this manual:
Touch Panel Display Keys: [Key Name]
Examples:
[Cancel]
[Close]
Control Panel Keys: Key Icon (Key Name)
Examples:
(Start)
(Stop)
Buttons on Computer Operation Screens: [Button Name]
Examples:
[OK]
[Add]
Displays Used in This Manual
Screen shots of the touch panel display used in this manual are those taken when the imageRUNNER ADVANCE 4251 has the following optional equipment attached to it:
Booklet Finisher-G1
Buffer Pass Unit-H1
External 2/3 Hole Puncher-B2
Cassette Feeding Unit-AF1
Web Access Software
Super G3 FAX Board
Note that functions that cannot be used depending on the model or options do not appear on the touch panel display.
The keys which you should press are marked with a , as shown below. When multiple keys can be pressed on the touch panel display, all keys are marked. Select the keys, which suit your needs.
Screen shots used in this manual may differ from the ones you actually see.
Illustrations Used in This Manual
Illustrations used in this manual are those displayed when the imageRUNNER ADVANCE 4251 has the following optional equipment attached to it:
Booklet Finisher-G1
Buffer Pass Unit-H1
Abbreviations Used in This Manual
In this manual, product names and model names are abbreviated as follows:
Microsoft Windows 2000 operating system: Windows 2000
Microsoft Windows Server 2003 operating system: Windows Server 2003
Microsoft Windows Server 2003 R2 operating system: Windows Server 2003 R2
Microsoft Windows XP operating system: Windows XP
Microsoft Windows Vista operating system: Windows Vista
Microsoft Windows Server 2008 operating system: Windows Server 2008
Microsoft Windows Server 2008 R2 operating system: Windows Server 2008 R2
Microsoft Windows Server 2012 operating system: Windows Server 2012
Microsoft Windows 7 operating system: Windows 7
Microsoft Windows 8 operating system: Windows 8
Microsoft Windows operating system: Windows
Microsoft Internet Explorer: Internet Explorer
Microsoft Windows Internet Explorer: Internet Explorer
Novell NetWare: NetWare
Apple Macintosh: Macintosh
Apple Mac: Mac
