Appendix
Relationship Between the Original Orientation and Paper Orientation
Use this appendix when stapling output printed on paper that is preprinted with a logo, etc.
If you are copying onto the back side of a previously printed sheet, load the paper as indicated below.
Paper drawer: Load the side to copy on face up.
Multi-purpose tray, Paper Deck Unit-B2: Load the side to copy on face down.
When Stapling on the Right
Other Settings
Example of Stapling Position
Corner: Top Right
Double: Right
LTR
Corner: Top Right
Double: Top
11" x 17", LGL, LTRR
Corner: Top Right
LTR
Corner: Top Right
Double: Right
Preprinted paper
Loading location: Paper drawer
Preprinted paper: Face up
Loading location: Multi-purpose tray
Preprinted paper: Face down
Loading location: Paper Deck Unit-B2
Original
Loading location: Platen glass
Original: Face down
Stapling setting
Corner: Top Right
Double: Right
Corner: Top Right
Double: Right
Corner: Top Right
Corner: Top Right
Double: Right
Loading location: Feeder
Original: Face up
Stapling setting
Corner: Top Right
Double: Right
Corner: Bottom Right
Double: Right
Corner: Top Right
Corner: Top Right
Double: Right
Auto Rotation Setting
Both ON and OFF available
Both ON and OFF available (ON when loaded vertically in the multi-purpose tray or vertically in a paper drawer)
When Stapling on the Left
Other Settings
Corner: Top Left
Double: Left
LTR
Corner: Top Left
Double: Top
Corner: Top Left
LTR
Corner: Top Left
Double: Left
Preprinted paper
Original
Original: Face down
Stapling setting
Corner: Top Left
Double: Left
Corner: Top Right
Double: Right
Corner: Top Left
Corner: Top Left
Double: Left
Original: Face up
Stapling setting
Corner: Top Left
Double: Left
Double: Right
Corner: Top Left
Corner: Top Left
Double: Left
When Not Stapling
Other Settings
Example Output
LTR
11" x 17", LGL
LTR, LTRR
11" x 17", LGL
Preprinted paper
Original
Original: Face down
Original: Face up
Unavailable Combination of Functions
The following tables show the unavailable combinations of settings when you want to set more than one function at a time.
Function
Functions that Cannot Be Used in Combination
Preset Zoom
N on 1*1, Booklet*1, Booklet: Saddle Stitch*1, Booklet: Add Cover (Printed/Leave Blank)*1, Booklet: Divided Booklet*1, Booklet: Creep Correction*1, Saddle Fold (Booklet)*1, Copy ID Card
Zoom by Percentage
XY Ratio
Auto Ratio/Auto XY Ratio
Auto Select Paper, Auto Select Paper, Auto Select Paper/Auto Orientation, Multi-Purpose Tray: Free Size, Repeat Images, Copy ID Card
Set by Length
Fit to Page
Multi-Purpose Tray: Free Size, N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Saddle Fold (Booklet), Repeat Images, Mirror Image, Page Numbering, Copy Set Numbering, Print Date, Watermark, Copy ID Card
*1 Priority is given to the Image Combination or functions on Booklet. You can also change the copy ratio.
Function
Auto Select Paper
Auto Ratio/Auto XY Ratio, Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Saddle Stitch, Add Cover (Print/Leave Blank), Saddle Fold, N on 1*1, Front Cover*2, Sheets/Chapter Pages*2, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Saddle Fold (Booklet), Repeat Images, Copy ID Card
Auto Ratio/Auto XY Ratio, Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Saddle Stitch, Add Cover (Print/Leave Blank), Saddle Fold, N on 1*1, Front Cover*2, Sheets/Chapter Pages*2, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Saddle Fold (Booklet), Different Size Originals, Repeat Images, Copy ID Card
Paper Drawer Auto Selection On/Off
Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Transparency Cover Sheets
Multi-Purpose Tray
Auto Ratio/Auto XY Ratio, Fit to Page, Auto Select Paper, Auto Select Paper/Auto Orientation, Paper Drawer Auto Selection On/Off, Collate, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple, Saddle Stitch, Add Cover (Print/Leave Blank), Saddle Fold, Offset, Hole Punch, 1-Sided 2-Sided, 2-Sided 2-Sided, Book  2-Sided, Book 2 Pages, N on 1, Shift: By Position, Shift: By Numeric Keys, Front Cover, Sheets/Chapter Pages, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Saddle Fold (Booklet), Share Copy with Local Device, Superimpose Image, Repeat Images, Page Numbering, Copy Set Numbering, Print Date, Watermark, Merge Job Blocks, Store in Mail Box, Store in Mail Box (Copy Upon Storing), Secure Watermark, Copy ID Card, Document Scan Lock (TL Code), Document Scan Lock (QR Code)
Auto Select Paper, Auto Select Paper/Auto Orientation, Paper Drawer Auto Selection On/Off, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Staple, Saddle Stitch, Add Cover (Print/Leave Blank), Saddle Fold, Hole Punch, Book  2-Sided, Book 2 Pages, N on 1, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Saddle Fold (Booklet), Store in Mail Box, Store in Mail Box (Copy Upon Storing), Copy ID Card
*2 You can set Auto Select Paper to the paper used for the main document.
Function
Collate
Multi-Purpose Tray: Free Size, Transparency Cover Sheets, Booklet*3, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank)*3, Booklet: Divided Booklet*3, Booklet: Creep Correction*3, Saddle Fold (Booklet)
Group
Multi-Purpose Tray: Free Size, Saddle Fold, Front Cover, Sheets/Chapter Pages, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Saddle Fold (Booklet), Copy Sample, Copy Set Numbering, Merge Job Blocks, Secure Watermark*4, Copy ID Card
Auto Select Paper, Auto Select Paper/Auto Orientation, Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Saddle Fold, Front Cover, Sheets/Chapter Pages, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Saddle Fold (Booklet), Share Copy with Local Device, Merge Job Blocks, Copy ID Card
Auto Select Paper, Auto Select Paper/Auto Orientation, Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Saddle Fold, Front Cover, Sheets/Chapter Pages, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Saddle Fold (Booklet), Copy Sample, Share Copy with Local Device, Copy Set Numbering, Merge Job Blocks, Secure Watermark*4, Copy ID Card
Offset Collate
Multi-Purpose Tray: Free Size, Saddle Fold, Booklet*3, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank)*3, Booklet: Divided Booklet*3, Booklet: Creep Correction*3, Saddle Fold (Booklet), Copy ID Card
Offset Group
Staple
Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Saddle Fold, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Saddle Fold (Booklet), Copy ID Card
Saddle Stitch
Auto Select Paper, Auto Select Paper/Auto Orientation, Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Saddle Fold, Hole Punch, 2-Sided 1-Sided, Book  2-Sided, Book 2 Pages, N on 1, Front Cover, Sheets/Chapter Pages, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Saddle Fold (Booklet), Share Copy with Local Device, Superimpose Image, Page Numbering, Copy Set Numbering, Print Date, Watermark, Merge Job Blocks, Copy ID Card
*3 You can combine these modes if you do not set Saddle Stitch in the Booklet mode.
*4 You cannot combine these modes with Copy Set Numbering for Secure Watermark.
Function
Saddle Fold
Auto Select Paper, Auto Select Paper/Auto Orientation, Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple, Saddle Stitch, Add Cover (Print/Leave Blank), Offset, Hole Punch, 2-Sided 1-Sided, Book  2-Sided, Book 2 Pages, N on 1, Front Cover, Sheets/Chapter Pages, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Saddle Fold (Booklet), Share Copy with Local Device, Superimpose Image, Page Numbering, Copy Set Numbering, Print Date, Watermark, Merge Job Blocks, Copy ID Card
Offset
Multi-Purpose Tray: Free Size, Saddle Fold, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Saddle Fold (Booklet), Copy ID Card
Hole Punch
Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Saddle Stitch, Add Cover (Print/Leave Blank), Saddle Fold, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Saddle Fold (Booklet)
Function
Interrupt Copy
Copy Sample, Share Copy with Local Device, Copy ID Card
Reserve Copy
1-Sided2-Sided
Multi-Purpose Tray: Free Size, Book 2 Pages, N on 1, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Saddle Fold (Booklet), Copy ID Card
2-Sided2-Sided
Multi-Purpose Tray: Free Size, Book 2 Pages, N on 1, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Saddle Fold (Booklet), Print & Check, Copy ID Card
2-Sided1-Sided
Saddle Stitch, Add Cover (Print/Leave Blank), Saddle Fold, Book 2 Pages, N on 1, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Saddle Fold (Booklet), Print & Check, Copy ID Card
Book2-Sided
Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Saddle Stitch, Add Cover (Print/Leave Blank), Saddle Fold, Book 2 Pages, N on 1, Erase Binding, Front Cover, Sheets/Chapter Pages, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Saddle Fold (Booklet), Different Size Originals, Repeat Images, Print & Check, Copy ID Card
Book2 Pages
Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Saddle Stitch, Add Cover (Print/Leave Blank), Saddle Fold, 1-Sided 2-Sided, 2-Sided 2-Sided, 2-Sided 1-Sided, Book  2-Sided, N on 1, Erase Binding, Front Cover, Sheets/Chapter Pages, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Saddle Fold (Booklet), Different Size Originals, Repeat Images, Print & Check, Copy ID Card
N on 1
Preset Zoom*1, Zoom by Percentage*1, XY Ratio*1, Set by Length*1, Fit to Page, Auto Select Paper, Auto Select Paper/Auto Orientation, Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Saddle Stitch, Add Cover (Print/Leave Blank), Saddle Fold, 1-Sided 2-Sided, 2-Sided 2-Sided, 2-Sided 1-Sided, Book  2-Sided, Book 2 Pages, Erase Original Frame, Erase Book Frame, Shift: By Numeric Keys, Front Cover, Sheets/Chapter Pages, Transparency Cover Sheets, Different Size Originals, Superimpose Image, Repeat Images, Mirror Image, Print & Check, Copy ID Card, Document Scan Lock (TL Code), Document Scan Lock (QR Code)
Fit to Page, N on 1, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Saddle Fold (Booklet), Repeat Images, Mirror Image, Page Numbering, Copy Set Numbering, Print Date, Watermark, Copy ID Card
Erase Book Frame
Erase Binding
Fit to Page, Book  2-Sided, Book 2 Pages, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Saddle Fold (Booklet), Repeat Images, Mirror Image, Page Numbering, Copy Set Numbering, Print Date, Watermark, Copy ID Card
Function
Gutter
Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Saddle Fold (Booklet), Repeat Images, Mirror Image, Copy ID Card
Shift: By Position
Multi-Purpose Tray: Free Size, Different Size Originals*5, Repeat Images, Mirror Image, Copy ID Card
Multi-Purpose Tray: Free Size, N on 1, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Saddle Fold (Booklet), Different Size Originals*5, Share Copy with Local Device, Repeat Images, Mirror Image, Page Numbering, Copy Set Numbering, Print Date, Watermark, Copy ID Card
Front Cover
Auto Select Paper*2, Auto Select Paper/Auto Orientation*2, Multi-Purpose Tray: Free Size, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Group, Saddle Stitch, Add Cover (Print/Leave Blank), Saddle Fold, Book  2-Sided, Book 2 Pages, N on 1, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Saddle Fold (Booklet), Superimpose Image, Repeat Images, Mirror Image, Merge Job Blocks, Copy ID Card
Auto Select Paper/Auto Orientation, Paper Drawer Auto Selection On/Off, Multi-Purpose Tray, Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Collate, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Group, Staple, Saddle Stitch, Add Cover (Print/Leave Blank), Saddle Fold, Offset, Hole Punch, 1-Sided 2-Sided, 2-Sided 2-Sided, 2-Sided 1-Sided, Book  2-Sided, Book 2 Pages, N on 1, Front Cover, Sheets/Chapter Pages, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Saddle Fold (Booklet), Share Copy with Local Device, Superimpose Image, Repeat Images, Mirror Image, Print & Check, Page Numbering, Copy Set Numbering, Print Date, Watermark, Merge Job Blocks, Copy ID Card
*5 You cannot combine these modes with Auto Select Paper.
Function
Booklet
Preset Zoom*1, Zoom by Percentage*1, XY Ratio*1, Set by Length*1, Fit to Page, Auto Select Paper, Auto Select Paper/Auto Orientation, Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Collate*3, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate*3, Offset Group, Staple, Saddle Stitch, Add Cover (Print/Leave Blank), Saddle Fold, Offset, Hole Punch, 1-Sided 2-Sided, 2-Sided 2-Sided, 2-Sided 1-Sided, Book  2-Sided, Book 2 Pages, Erase Original Frame, Erase Book Frame, Erase Binding, Gutter, Shift: By Numeric Keys, Front Cover, Sheets/Chapter Pages, Transparency Cover Sheets, Different Size Originals, Share Copy with Local Device, Superimpose Image, Repeat Images, Mirror Image, Print & Check, Print Date, Watermark, Merge Job Blocks, Secure Watermark, Copy ID Card, Document Scan Lock (TL Code), Document Scan Lock (QR Code)
Preset Zoom*1, Zoom by Percentage*1, XY Ratio*1, Set by Length*1, Fit to Page, Auto Select Paper, Auto Select Paper/Auto Orientation, Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Collate, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple, Saddle Stitch, Add Cover (Print/Leave Blank), Saddle Fold, Offset, Hole Punch, 1-Sided 2-Sided, 2-Sided 2-Sided, 2-Sided 1-Sided, Book  2-Sided, Book 2 Pages, Erase Original Frame, Erase Book Frame, Erase Binding, Gutter, Shift: By Numeric Keys, Front Cover, Sheets/Chapter Pages, Transparency Cover Sheets, Different Size Originals, Share Copy with Local Device, Superimpose Image, Repeat Images, Mirror Image, Print & Check, Print Date, Watermark, Merge Job Blocks, Secure Watermark, Copy ID Card, Document Scan Lock (TL Code), Document Scan Lock (QR Code)
Function
Copy Sample
Group, Rotate 90 Degrees: Group, Offset Group, Interrupt Copy, Reserve Copy, Share Copy with Local Device, Store in Mail Box, Copy ID Card
Auto Select Paper/Auto Orientation, Book  2-Sided, Book 2 Pages, N on 1, Shift: By Position*5, Shift: By Numeric Keys*5, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Saddle Fold (Booklet), Repeat Images, Copy ID Card
Multi-Purpose Tray: Free Size, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Saddle Stitch, Add Cover (Print/Leave Blank), Saddle Fold, Interrupt Copy, Reserve Copy, Shift: By Numeric Keys, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Saddle Fold (Booklet), Copy Sample, Mirror Image, Print & Check, Merge Job Blocks, Store in Mail Box, Store in Mail Box (Copy Upon Storing), Secure Watermark, Copy ID Card, Document Scan Lock (TL Code), Document Scan Lock (QR Code)
Sharpness
Secure Watermark, Document Scan Lock (TL Code), Document Scan Lock (QR Code)
Superimpose Image
Multi-Purpose Tray: Free Size, Saddle Stitch, Add Cover (Print/Leave Blank), Saddle Fold, N on 1, Front Cover, Sheets/Chapter Pages, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Saddle Fold (Booklet), Repeat Images, Print & Check, Page Numbering, Copy Set Numbering, Print Date, Watermark, Merge Job Blocks, Store in Mail Box, Store in Mail Box (Copy Upon Storing), Secure Watermark, Copy ID Card, Document Scan Lock (TL Code), Document Scan Lock (QR Code)
Nega/Posi
Repeat Images
Auto Ratio/Auto XY Ratio, Fit to Page, Auto Select Paper, Auto Select Paper/Auto Orientation, Multi-Purpose Tray: Free Size, Book  2-Sided, Book 2 Pages, N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Gutter, Shift: By Position, Shift: By Numeric Keys, Front Cover, Sheets/Chapter Pages, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Saddle Fold (Booklet), Different Size Originals, Superimpose Image, Mirror Image, Print & Check, Merge Job Blocks, Secure Watermark, Copy ID Card, Document Scan Lock (TL Code), Document Scan Lock (QR Code)
Mirror Image
Fit to Page, N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Gutter, Shift: By Position, Shift: By Numeric Keys, Front Cover, Sheets/Chapter Pages, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Saddle Fold (Booklet), Share Copy with Local Device, Repeat Images, Page Numbering, Copy Set Numbering, Print Date, Watermark, Merge Job Blocks, Store in Mail Box, Store in Mail Box (Copy Upon Storing), Secure Watermark, Copy ID Card, Document Scan Lock (TL Code), Document Scan Lock (QR Code)
Function
Print & Check
2-Sided 2-Sided, 2-Sided 1-Sided, Book  2-Sided, Book 2 Pages, N on 1, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Saddle Fold (Booklet), Share Copy with Local Device, Superimpose Image, Repeat Images, Merge Job Blocks, Store in Mail Box, Copy ID Card
Page Numbering
Fit to Page, Multi-Purpose Tray: Free Size, Saddle Stitch, Add Cover (Print/Leave Blank), Saddle Fold, Erase Original Frame, Erase Book Frame, Erase Binding, Shift: By Numeric Keys, Transparency Cover Sheets, Superimpose Image, Mirror Image, Copy ID Card, Document Scan Lock (TL Code), Document Scan Lock (QR Code)
Copy Set Numbering
Fit to Page, Multi-Purpose Tray: Free Size, Group, Rotate 90 Degrees: Group, Offset Group, Saddle Stitch, Add Cover (Print/Leave Blank), Saddle Fold, Erase Original Frame, Erase Book Frame, Erase Binding, Shift: By Numeric Keys, Transparency Cover Sheets, Superimpose Image, Mirror Image, Secure Watermark, Copy ID Card, Document Scan Lock (TL Code), Document Scan Lock (QR Code)
Print Date
Fit to Page, Multi-Purpose Tray: Free Size, Saddle Stitch, Add Cover (Print/Leave Blank), Saddle Fold, Erase Original Frame, Erase Book Frame, Erase Binding, Shift: By Numeric Keys, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Saddle Fold (Booklet), Superimpose Image, Mirror Image, Secure Watermark, Copy ID Card, Document Scan Lock (TL Code), Document Scan Lock (QR Code)
Watermark
Merge Job Blocks
Multi-Purpose Tray: Free Size, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Group, Saddle Stitch, Add Cover (Print/Leave Blank), Saddle Fold, Front Cover, Sheets/Chapter Pages, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Saddle Fold (Booklet), Share Copy with Local Device, Superimpose Image, Nega/Posi, Repeat Images, Mirror Image, Print & Check, Copy ID Card
Store in Mail Box
Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Copy Sample, Share Copy with Local Device, Superimpose Image, Mirror Image, Print & Check, Copy ID Card
Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Share Copy with Local Device, Superimpose Image, Mirror Image, Copy ID Card
Secure Watermark
Multi-Purpose Tray: Free Size, Group*4, Rotate 90 Degrees: Group*4, Offset Group*4, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Saddle Fold (Booklet), Share Copy with Local Device, Sharpness, Superimpose Image, Nega/Posi, Repeat Images, Mirror Image, Copy Set Numbering, Print Date, Watermark, Document Scan Lock (TL Code)
Copy ID Card
Preset Zoom, Zoom by Percentage, XY Ratio, Auto Ratio/Auto XY Ratio, Set by Length, Fit to Page, Auto Select Paper, Auto Select Paper/Auto Orientation, Multi-Purpose Tray: Free Size, Multi-Purpose Tray: Custom Size, Collate, Group, Rotate 90 Degrees: Collating, Rotate 90 Degrees: Group, Offset Collate, Offset Group, Staple, Saddle Stitch, Add Cover (Print/Leave Blank), Saddle Fold, Offset, Interrupt Copy, 1-Sided 2-Sided, 2-Sided 2-Sided, 2-Sided 1-Sided, Book  2-Sided, Book 2 Pages, N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Gutter, Shift: By Position, Shift: By Numeric Keys, Front Cover, Sheets/Chapter Pages, Transparency Cover Sheets, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Saddle Fold (Booklet), Copy Sample, Different Size Originals, Share Copy with Local Device, Superimpose Image, Nega/Posi, Repeat Images, Mirror Image, Print & Check, Page Numbering, Copy Set Numbering, Print Date, Watermark, Merge Job Blocks, Store in Mail Box, Store in Mail Box (Copy Upon Storing), Document Scan Lock (TL Code), Document Scan Lock (QR Code)
Multi-Purpose Tray: Free Size, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Saddle Fold (Booklet), Share Copy with Local Device, Sharpness, Superimpose Image, Nega/Posi, Repeat Images, Mirror Image, Page Numbering, Copy Set Numbering, Print Date, Watermark, Secure Watermark, Copy ID Card, Document Scan Lock (QR Code)
Multi-Purpose Tray: Free Size, Booklet, Booklet: Saddle Stitch, Booklet: Add Cover (Printed/Leave Blank), Booklet: Divided Booklet, Booklet: Creep Correction, Saddle Fold (Booklet), Share Copy with Local Device, Sharpness, Superimpose Image, Nega/Posi, Repeat Images, Mirror Image, Page Numbering, Copy Set Numbering, Print Date, Watermark, Copy ID Card, Document Scan Lock (TL Code)
» Copy » Appendix
0CYL-0R8
