[Upright Image]:
Press this if you are placing originals upright.
[Sideways Image]:
Press this if you are placing originals sideways.
Upright Image
Sideways Image
Vertical Placement
Horizontal Placement
Vertical Placement
If you set any two of [Page Numbering], [Copy Set Numbering], or [Watermark] to print in the same position, a confirmation message appears when you press
(Start). |
(numeric keys).|
If no date is set, the date set in [Date/Time Settings] is printed. Confirm that the date and time settings are correct. (See "Current Date and Time.")
Printing performance may not be optimal, depending on the original content and combination of settings.
If you use [Print Date] with [Add Cover] or [Insert Sheets], numbers will not be printed on the inserted pages.
You can also adjust the position of the date. (See "Registering/Editing/Deleting User-Defined Text for Page Numbers and Watermarks.")
