You can print documents with large numbers of pages as a booklet.
Benefits of Making a Booklet
You can conveniently check the content by flipping through the pages like a book.
Required Condition
The printer driver is installed.
The Booklet Finisher is attached to the machine (for creating saddle stitched booklets).
This section describes how to saddle stitch a document to have two pages printed on each side of a sheet. This means a 40 page document will be printed using 10 sheets of paper.
The screens may differ, depending on the model of the machine and on attached optional products.
From the [File] menu of the application software you are using to print the document → select [Print].
The [Print] dialog box is displayed.
Select the printer to use → select [Finishing].
The [Finishing] preferences panel is displayed.
The screen may differ, depending on the type and version of the printer driver and the application software you are using.
Select [Booklet Printing] from [Print Style].
On the [Detailed Settings for Booklet] dialog box, displayed when [Booklet] is clicked, you can specify the detailed settings for the booklet, such as its layout.
4.
Select [Saddle Stitch] from the [Saddle Stitch Setting].
5.
Click [Print].
The document is reduced and printed horizontally on the LTR paper like the facing pages of a book.
